Engine knock - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 09-22-2006, 05:22 PM Thread Starter
Engine knock
hello all,
i have a 2003 with 14k...internal noise started about 3 months ago, then went away for awhile, now back again...sounds like metal ball in paint can, a rock in the motor (know not possible)/noise is pretty loud....coming from near top of rear cylinder...gets louder above 1800 rpm, goes totally away after engines warms up..approx. 15-20 minutes. no other issues noted, other than idle is off a bit when it is cold. any help would be appreciated.
njeagles is offline
post #2 of 21 (permalink) Old 09-22-2006, 06:02 PM
tankist's Avatar
Send a message via Skype™ to tankist
ACCT dieseling by a chance?
Ride Safe
Anton.
tankist is offline
post #3 of 21 (permalink) Old 09-22-2006, 06:10 PM Thread Starter
should I use "Grambo Trick" to fix??
njeagles is offline
post #4 of 21 (permalink) Old 09-22-2006, 06:27 PM
Once Banned
cegodsey's Avatar
That's about when my 2000 started doing it. Try Grambo, then if that doesn't work, try rebuilding the ACCT's. Use the TOC manufacturing instructions from the links page, but use your current springs. I'm not really convinced that the TOC springs are any better unless you have a lot more miles than 14K. Make sure you get the preload accomplished. Doesn't have to be a full turn, but should be at least a half.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #5 of 21 (permalink) Old 09-22-2006, 06:34 PM
Sky Rider's Avatar
I agree with cegodsey. It sounds like the ACCTs. I can't vouch for the rebuild but it does make sense if the Grambo trick doesn't work.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #6 of 21 (permalink) Old 09-22-2006, 08:38 PM
I just replaced the ACCT on my '96 750 Vulcan. $70.00 for the part from the local dealer. But now mine is making "rattling" sound in the front cylinder. It goes away after about 30 minutes. Maybe lifters ? I don't have a clue at this point which is why I am here. Any suggestions would be great.
Thanks......
RdTecBiker is offline
post #7 of 21 (permalink) Old 09-22-2006, 10:48 PM
rontaub
rontaub's Avatar
If ACCT is Automatic cam chain tensioner then I agree. I had mine replacedby the dealer at 5800 miles and it got rid of the ticking noise that was there when the engine is cold.
rontaub is offline
post #8 of 21 (permalink) Old 09-23-2006, 11:47 AM Thread Starter
thx all..the grambo trick worked..however, i would like to replace the acct to ensure problem does not come back anytime soon.. do you recommend rebuilding, getting new unit from dealer, or is there aftermarket that fairs better??...thx
njeagles is offline
post #9 of 21 (permalink) Old 09-23-2006, 01:05 PM
i got a pair of new old stock ACCT's from ebay for $40 and ordered the TOC springs and rebuilt mine at 11,000 miles used a turn of preload. if the plunger isn't binding or worn, i don't think you need a total replacement, just springs will do wonders
free wheel-e is offline
post #10 of 21 (permalink) Old 09-23-2006, 01:54 PM
Sky Rider's Avatar
The springs are what tend to weaken as the bike sits for long periods of time. You can either do the mod to the OEM springs or order the TOC springs and rebuild from there. As long as the plunger is not worn and the chains not stretched beyond their limit, all should be well.
BTW, there are 2 ACCTs, one for each cylinder.
If you want to replace them with OEM ACCTs, go either Bike Bandit (a bit more expensive but faster and cheaper shipping) or Ron Ayers (less up front cost but takes longer to get to you and shipping is more).
www.bikebandit.com
www.ronayers.com
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
