Help Broken Radiator fan! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 09-20-2006, 03:09 PM Thread Starter
Uber Member
Well looks like i broke the radiator fan in my stator replacement. It seems as iff the fan blade assmebly has come off the shaft from the motor. Curious if anyone has seen how it goes on, as i would like to fix it all in one go in the morning....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #2 of 9 (permalink) Old 09-20-2006, 07:58 PM
Rubline's Avatar
I would think that there must be some sort of set screw that secures the fan to the motor shaft.
Rubline is offline
post #3 of 9 (permalink) Old 09-21-2006, 12:54 AM
Once Banned
cegodsey's Avatar
Hehe. Sorry.
Well, you could always try glue. Or JBweld. Ackk! My daughter took my manual - I can't look it up! Oh, wait, I got the pdf...
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #4 of 9 (permalink) Old 09-21-2006, 01:43 AM Thread Starter
Uber Member
Why did your daughter take your manual for? to balance a table?
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #5 of 9 (permalink) Old 09-21-2006, 01:55 AM
Once Banned
cegodsey's Avatar
Where's your manual?
Doesn't matter, it shows the fan as a complete unit.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #6 of 9 (permalink) Old 09-21-2006, 02:06 AM
Ernie's Avatar
Send a message via MSN to Ernie
My fan starting slipping on the motor shaft a few years ago. If I remember correctly, it is just a tight fit onto the shaft & there was no setscrew or anything holding it on.
I used a good quality epoxy resin to glue it back on & allowed it to set overnight. Haven't had any problems since.
Hope this helps.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #7 of 9 (permalink) Old 09-21-2006, 02:50 AM Thread Starter
Uber Member
Thanks!!! i will find out if that is it in the morning.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #8 of 9 (permalink) Old 09-21-2006, 03:00 AM
Ernie's Avatar
What do you mean? It IS the morning - here in the UK at least!
Only joking Hizzo3. Hope you get the problem sorted.
Take care & ride safe.
Ernie.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #9 of 9 (permalink) Old 09-21-2006, 04:24 AM
Must have been all that power you're making now got the bike to try and use the fan blade as a propeller !!
If it is just a press fit, you probably could still add a set screw to the thing.
