Mixologist - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 09-18-2006, 08:04 PM Thread Starter
Geek
rnewell's Avatar
Question Mixologist
Got another jug of oil for the bike tonight. I usually get Valvoline. They didn't have any. So I got Castrol. Now I have a bunch of mostly empty 5 quart oil jugs of different brands. All 10/40. Can you mix them together ? I know, I know. One side of the brain says don't do it. The other side says go ahead. Any oil experts out there ?
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #2 of 26 (permalink) Old 09-18-2006, 08:07 PM
Once Banned
cegodsey's Avatar
Go ahead.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 26 (permalink) Old 09-18-2006, 08:12 PM
As long as ya don't mix synth & dino, ya shouldn't have any troubles.
Even if they were different weights you could still mix them. You'd just end up with the average weight of all of them.
post #4 of 26 (permalink) Old 09-18-2006, 08:16 PM
what about semi-synth and dino or semi-synth and synth?
kait is offline
post #5 of 26 (permalink) Old 09-18-2006, 08:23 PM
Once Banned
cegodsey's Avatar
Sure. Semi-synth-squared. If you really couldn't mix the two, then how would you get all the oil out of the engine when you changed it?
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #6 of 26 (permalink) Old 09-18-2006, 08:26 PM Thread Starter
Geek
rnewell's Avatar
Q-Tips.
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
post #7 of 26 (permalink) Old 09-18-2006, 08:33 PM
Good answer..!
kait is offline
post #8 of 26 (permalink) Old 09-18-2006, 08:48 PM
tankist's Avatar
Send a message via Skype™ to tankist
not an expert, but i dont see why not. actually i don't see why not mix dino and sintetic. it is all mixed when they recycle oil anyways.
IMHO
Ride Safe
Anton.
tankist is offline
post #9 of 26 (permalink) Old 09-18-2006, 08:53 PM
HAWK
Ccspinner's Avatar
Would be the same as Dura Blend.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 26 (permalink) Old 09-18-2006, 09:05 PM
As far as synth & dino, well, that's what I've always heard.
But then ya all got me more interested so I did a quick search and got this info ....
Mixing brands is not the best practice because the additive systems in each may be different and when mixed may not function as efficiently as desired. However, no serious problems will occur if you must add a different brand of equivalent quality between oil changes. It is very important to maintain proper oil level.
And the main question answered here....
Mineral oils are based on oil that comes from dear old Mother Earth which has been refined. Synthetic oils are entirely concocted by chemists wearing white lab coats in oil company laboratories. The only other type is semi-synthetic, sometimes called premium, which is a blend of the two. It is safe to mix the different types, but it's wiser to switch completely to a new type rather than mixing.
Despite their name, most synthetic derived motor oils (ie Mobil 1, Castrol Formula RS etc ) are actually derived from mineral oils - they are mostly Polyalphaolifins and these come from the purest part of the mineral oil refraction process, the gas. PAO oils will mix with normal mineral oils which means Joe public can add synthetic to his mineral, or mineral to his synthetic without his car engine seizing up. The most stable bases are polyol-ester (not polyester, you fool). When I say 'stable' I mean 'less likely to react adversely with other compounds.' Synthetic oil bases tend not to contain reactive carbon atoms for this reason. Reactive carbon has a tendency to combine with oxygen creating an acid. As you can imagine, in an oil, this would be A Bad Thing. So think of synthetic oils as custom-built oils. They're designed to do the job efficiently but without any of the excess baggage that can accompany mineral based oils.
(Note from Hyper.....I don't think this is the synth oil we use)
Pure synthetic oils (polyalkyleneglycol) are the types used almost exclusively within the industrial sector in polyglycol gearbox oils for heavily loaded gearboxes. These are typically concocted by intelligent blokes in white lab coats. These chaps break apart the molecules that make up a variety of substances, like vegetable and animal oils, and then recombine the individual atoms that make up those molecules to build new, synthetic molecules. This process allows the chemists to actually "fine tune" the molecules as they build them. Clever stuff. But Polyglycols don't mix with normal mineral oils.
If you want to read more about oil, check out 'The Engine Oil Bible', where most of this info came from.
