oops, overfilled oil - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-25-2006, 09:41 AM Thread Starter
Did oil change a while back, manual said 4 litres but as I was putting in the fourth i noticed that it was over the top of site glass around 3 and half or so, bike was on center stand while doing this by the way. I replaced the oil filter at the same time so I figured it would come down a little but it hasn't. Could I be doing any damage to anything by having to much oil in there?
Bradman is offline
post #2 of 6 (permalink) Old 08-25-2006, 09:45 AM
HAWK
Ccspinner's Avatar
4 Litres is about 3 1/2 quarts, when you check it you do let it run and then shut it off, put it on the center stand and wait about 5 minuts then check. If there is a air bubble still able to be seen in the glass you are ok. There is no real damage you can do unless you way overfill by a couple of quarts, they you can run the risk of hydrolocking, it would also be smoking alot. Hope this helps
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 6 (permalink) Old 08-25-2006, 11:08 AM
fergy's Avatar
Actually 4 liters = 4.2 liquid quarts, but no one has been able to get all that oil that the mfg calls for, in there. I would suggest that you open the side drain with the bike on the centerstand and drain out what ever it takes to get the level right. It's not a big deal to do and I wouldn't want to run the engine over full on oil.
Just my 2 cents...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 6 (permalink) Old 08-25-2006, 11:40 AM
Uber Member
dont use the side drain cover, that is how i cut the gasket there, it pushed it to the edge, and i didnt see it when i tightened her back up and *cut* it went. use the bottom drain plug. there will just be a lil excessive sloshing from the crank dipping into the oil, and may make extra noise. Nothing to be that worried on.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 6 (permalink) Old 08-25-2006, 06:57 PM
Once Banned
cegodsey's Avatar
I was told way back by a GMC engineer that extra oil in the crankcase will get frothy from the air mixed in - caused by the piston rods "slapping" or "whipping" the oil. They also suggested running a half a quart low to decrease the slapping and increase the horsepower. Both engines that I ran 1/2 a quart low on developed problems, so I'm not sure what to believe. In any case, I'm not draining it out. Haven't had any trouble with noise.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 6 (permalink) Old 08-25-2006, 08:31 PM
Sky Rider's Avatar
I used the side plug when I overfilled mine and had no problems. I think the bike gremlins decide to cause different problmes for us to keep us guessing and contradicting each other.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
