coolant spraying - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-17-2012, 05:41 PM Thread Starter
coolant spraying
Hey all
I'm new to the forum. I have a coolant leak from the front of the front cylinder. there is a hole about half way down the cylinder. looks like there should be a hose on it. No clue where to connect it. it sprays out when turnin the bike over.
any help would be greatly appreciated
aconkright is offline
post #2 of 10 (permalink) Old 07-20-2012, 11:39 AM Thread Starter
A little clarification. The leak is coming from a nipple right next to the exhaust. Any ideas where its supposed to go? What its for? I wanna get riding as soon as possible
post #3 of 10 (permalink) Old 07-20-2012, 12:14 PM
there is a coolant bleed screw on the cylinder...but not exactly sure if that is what you are looking at.
look through this thread to see if this helps:
https://www.vn750.com/forum/showthread.php?t=6116
post #4 of 10 (permalink) Old 07-21-2012, 02:22 PM Thread Starter
not really. but it help i will have to change/ flush coolant system. one i i figure it out. it's on the front next to the exhaust. if your lookin at it from the front with radiator removed it would be on the right side. no clue what it is for or where it goes.
post #5 of 10 (permalink) Old 07-21-2012, 02:24 PM
a photo might help........
post #6 of 10 (permalink) Old 07-21-2012, 04:22 PM Thread Starter
heres a pic without taking the radiator off. this if from the front left of the bike
post #7 of 10 (permalink) Old 07-21-2012, 06:06 PM
I think that's the crankcase breather outlet. If so, it shouldn't be spraying coolant.
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #8 of 10 (permalink) Old 07-21-2012, 06:24 PM
That is the breather outlet and it's spraying oil not, coolant. Simply attach a hose to it and a breather filter on the other end and aim it upward. Then cap or plug the hole in the original airbox if still equipt or simply run the hose to it like original.
Rebel13 is offline
post #9 of 10 (permalink) Old 07-30-2012, 03:29 AM
Daddy D
im haveing the same problem but mine is just pooring what looks like water and oil mixed. would anyone know why it would be doin so
Daddy D is offline
post #10 of 10 (permalink) Old 07-30-2012, 07:02 AM
Ndr
If your getting coolant/water mixed into your oil, I think that's a pretty good sign that you've got a gasket leak somewhere. (aka head gasket)
If you capture whats coming out into a clear glass jar (or similar) and let it sit for a little while, the two liquids should seperate and you should be able to tell what was being mixed in with the oil (if anything)
Ndr is offline
