Discoloration on one pipe - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 07-16-2012, 09:55 PM Thread Starter
Question Discoloration on one pipe
Hey all I was wondering if anyone has seen this. My right pipe (if your sitting on the bike) is "blue-ing" near the engine and I cannot polish it off with any amount of chrome polish. The left pipe is not doing this and I know its firing because its just as hot as the right one. Take a look at the pics and let me know what you think, if I should be concerned ot not.
Thanks in advance guys.
ID:	4698   Click image for larger version
jj23 is offline
post #2 of 14 (permalink) Old 07-16-2012, 10:33 PM
romeobravo172
romeobravo172's Avatar
The left pipe is covered by the heat shield which pretty much covers the entire header on that side! The right is pretty much exposed all the way to back under the foot peg. The blueing is caused by to much heat or that cylinder is running to lean. I think blueing high is lean, and low is rich. I might be wrong, am sure it will get clarified, just ask here and you will find the answer!! What kind of seat is that?
romeobravo172 is offline
post #3 of 14 (permalink) Old 07-16-2012, 10:43 PM
JM2001's Avatar
You have to remove the heat shield on the left exhaust to see what color the pipe is. Romeo is correct, blueing near the cylinder means you are running lean. Blueing 4 or 5 inches down on the pipe usually means a rich condition.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 14 (permalink) Old 07-16-2012, 11:01 PM
'03 VN750 "Rosie"
bstew7890's Avatar
Mine is worse, but I was able to improve it somewhat with a polish called "Wenol". I got it from a vendor at a bike rally who said to put it on while the pipe is hot, which I did. It stinks like crazy, and didn't totally fix the blueing, but I think it helped at least.
ID:	4701   Click image for larger version
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #5 of 14 (permalink) Old 07-16-2012, 11:19 PM
romeobravo172
Mine actually turns a gold color, don't know what that means! I use Blue Magic, think I got it at one of the local auto stores, does help and also that is a good overall metal polish. Does real good on alum.
post #6 of 14 (permalink) Old 07-16-2012, 11:53 PM
My front one is a bit Mellow Yellow too. Which is a bit better than being blue, I guess.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #7 of 14 (permalink) Old 07-16-2012, 11:59 PM
romeobravo172
Hey, that is a good description! I am starting to think it has something to do with running iridum plugs!!!! (LOL)
post #8 of 14 (permalink) Old 07-17-2012, 12:23 AM
Ohhhhhhhhhh, pls don't start THAT subject again !
Williamtech
post #9 of 14 (permalink) Old 07-17-2012, 12:25 AM
romeobravo172
Ya know I just had to do that!!!
post #10 of 14 (permalink) Old 07-17-2012, 12:29 AM
ROFLMAO !
WilliamTech
