goofy idle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-15-2012, 07:37 PM Thread Starter
yamahondakawi1's Avatar
goofy idle
It seems to have a little popping at idle coming from the rear cylinder any ideas of what it could be?
yamahondakawi1 is offline
post #2 of 6 (permalink) Old 07-15-2012, 07:58 PM
bad exhast doughnut gasket? Vacuum leak?? does it do it at higher RPMs?
post #3 of 6 (permalink) Old 07-15-2012, 08:22 PM Thread Starter
it kinda sounds like a misfire
post #4 of 6 (permalink) Old 07-15-2012, 09:05 PM
check the rear carb inlet boot for cracks or vacuum leaks, also make sure you are getting spark on both rear plugs.
post #5 of 6 (permalink) Old 07-16-2012, 12:19 AM
Crap, I WAS in 5th gear.
Make sure the vacuum line (or plug) is present and not leaking.
Kelly2001 is offline
post #6 of 6 (permalink) Old 07-16-2012, 06:01 PM
Mine was popping when I started it when it was cold. I thought it was a vacuum leak. Come to find out the rear carb was running lean, and it was backfiring into the carb as it was starting.
I cleaned then, and adjusted the mixture screws and it went away.
Like they said, check the exhaust gasket at the pipe, and check for vacuum leaks.
TSmith68 is offline
