Replace a 750 with a 700? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-12-2012, 09:57 PM Thread Starter
Found a vn700 with about 10k miles as a possible engine replacement for my 750. I know that it should bolt right into my frame and all. Just wondering if I'd need to do any carb work or anything else to make it right. Anyone ever done this? Have any tips for it?
Jacknh is offline
post #2 of 6 (permalink) Old 07-12-2012, 10:26 PM
direct swap.. nothing needs to be changed to go from one to the other... when we are talkling whole engines. now if we were talking just the heads... you would need the jugs, pistons, piston rings, connecting rods, and rod bearings. all the rest of the parts are interchangable
post #3 of 6 (permalink) Old 07-12-2012, 10:30 PM
If your just swapping engines and keeping the 750 carbs, you may need to downsize the jets.
Rebel13 is offline
post #4 of 6 (permalink) Old 07-13-2012, 05:25 AM Thread Starter
That's what I was thinking, too. But if that's the only issue, then it's probably worth doing.
Jacknh is offline
post #5 of 6 (permalink) Old 07-13-2012, 08:37 AM
why would you have to rejet.. the 700 and the 750 are jetted the same from the factory.
post #6 of 6 (permalink) Old 07-13-2012, 09:05 AM Thread Starter
Good to know! I'll just run it and see what happens.
Jacknh is offline
