impeller shaft bearing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-12-2012, 09:55 AM Thread Starter
Is it possible to remove the outter bearing of the impeller shaft, without separating the crankcase?
rdias is offline
post #2 of 3 (permalink) Old 07-12-2012, 10:18 AM
You can replace the impeller, mechanical seal, and o ring, but not the bearing for it without cracking the case.
post #3 of 3 (permalink) Old 07-12-2012, 04:30 PM Thread Starter
That I know. I was wondering if anyone has come across with the same problem and replace it without tearing the engine apart. I know it is dificult.
It is a lot of work just to replace that bearing.
rdias is offline
