Bizarre Rattle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 07-11-2012, 11:58 PM Thread Starter
Bizarre Rattle
Hey all,
I recently installed TOC's MCCTs which, obviously, quieted the cam chains. Now the bike has this rattle which moves with the rpms. Can't hear at idle, only when riding the bike. Bike is performing well at all rpms. The noise sound just like the front brakes when they are in use.
I have tried searching for the noise, but all I can come up with is a rattle in the right-front turn signal and maybe the plastic guard over the radiator. The rattle in the signal is the deflectector inside the housing. The plastic cover for the radiator would be the least likely the culprit.
I thought it was my garage door remote that I use as a keychain, but that wasn't it either. The noise is definately coming from somewhere between my legs to the front of the bike.
Any ideas would be helpful, thanks!
post #2 of 12 (permalink) Old 07-12-2012, 12:09 AM
Can you hear the rattle sitting still, but reving the engine up?
post #3 of 12 (permalink) Old 07-12-2012, 12:23 AM Thread Starter
Not really. I don't hear it until I hit 5K+ when riding and I don't like doing that without a load on the motor.
I can't even feel it when I hear it. That lets me know it not engine/tranny related. It has to be something lose that I overlooked.
post #4 of 12 (permalink) Old 07-12-2012, 07:46 AM
try resting your toe on the oval heat shield thingy on the exhaust when the rattle starts
post #5 of 12 (permalink) Old 07-12-2012, 09:15 AM
did you earshave?my left pod filter was hitting on the gas tank at about 5k would rattle the tank a little.had to raise the tank a little with spacers
post #6 of 12 (permalink) Old 07-12-2012, 09:21 AM
Are your (4?) radiator mounting bolts tight ? The radiator cover/Shield mounts with 3 bolts.
WilliamTech
post #7 of 12 (permalink) Old 07-12-2012, 10:34 AM
I have a similar rattle that I had since day one....drove me bananas for a long time.
I hear it at 4K rpm and it is on the right side somewhere.....
I recently decided that it had to be the throttle cables that have the wire "spring" over the outer casing. Under the neck covers they run down the right side past the radiator cap. I wrapped them with rubber tape and realized they were rattling together and against the radiator cap. They are still making some noise further down, so I plan on using gas hose to dampen them where they can make contact with other areas....like where they are routed just under the right "EAR" mounting bolts.
It seemed to help in my case.....just curious if others have had similar rattles.
post #8 of 12 (permalink) Old 07-12-2012, 10:46 AM
I've read on this forum where another had the cable rattle issue below the right ear...
---resolved with splitting a piece of fuel line, placing over cable....
WilliamTech
post #9 of 12 (permalink) Old 07-12-2012, 11:50 AM Thread Starter
Bike doesn't have stock exhaust, so no heat shield.
I'll have to check out the throttle cables when I get a chance. Thanks!
post #10 of 12 (permalink) Old 07-12-2012, 12:58 PM
The problem with MCCT's is that now you will hear lots of little rattles and what nots that you didn't hear before. And when like in my case, MCCT's combined with HD Sportster Muff's, you hear every little rattle, like the keys in the bar, the "Bell" under the radiator, the front tire contact patch rolling on the road, and on, and on....
I gave up on most noises as chasing Gremlins, and that's what the bell is for.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
