dumb question on plug #s - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 08-19-2006, 08:31 AM Thread Starter
Headbanger/Popes of Hell
ruger's Avatar
i know this is a dumb question, but i gotta ask! if the bike has only 2 cylinders then why does it have 4 spark plugs?
ruger is online now
post #2 of 16 (permalink) Old 08-19-2006, 09:20 AM
It has 2 per cyl.
vulcan460 is offline
post #3 of 16 (permalink) Old 08-19-2006, 09:34 AM
Search Goddess
Dianna's Avatar
It is set up with two plugs per cylinder for better, cleaner firing.. The spark ignites milliseconds from each other , like bambam.. bambam.. with the second igniting any leftover gas
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 16 (permalink) Old 08-19-2006, 02:30 PM
HAWK
Ccspinner's Avatar
And there you go, good explination Dianna
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 16 (permalink) Old 08-19-2006, 07:11 PM
Once Banned
cegodsey's Avatar
The real reason for the 2 extra plugs is that they balance the charge of the other plugs. When you pump 5-10 thousand volts through a plug, it creates a negative charge in order to fulfill the laws of energy conservation. Similar to when you drop something in water, the water will fill in where it was displaced, and shoot back up some. If it wasn't for the law of energy conservation (lec), the water would fill in and flatten out, without a splash. Then anybody would be able to make an olympic dive. Anyhow, the secondary plug fires right after the first one, to eliminate the negative backwards energy, thus fulfulling the lec in a way such as to produce the least amount of heat/damage to the coils. As an added benefit, it also burns some extra fuel that did not combust, although the time between the two sparks is very small. Also, due to little inefficiencies, such as resistances in the wire and coil, the second plug will not fire as powerfully as the first.
This is why most engines are an even number of cylinders.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 16 (permalink) Old 08-19-2006, 10:03 PM
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Two plugs per cylinder
Once had an 84' Nissan Pickup that had two plugs per cylinder, it was
considered one of the best engines Nissan ever made.
On that engine I was told that one plug was at the intake and the other
at exhaust...Nap Z engine.
"When the sun's comin' up,
I got cakes on the griddle.
Life ain't nothin' but a funny funny riddle,
Thank God I'm a Country Boy!"
norsseman is offline
post #7 of 16 (permalink) Old 08-20-2006, 11:29 AM Thread Starter
ruger's Avatar
thank you, vulcan460, for that simple answer. thank you, Dianna, for the better explination. thank you cegodsey, for your (mind blowing/overkill) explination. that made my head hurt!
thanks all'
ruger
ruger is online now
post #8 of 16 (permalink) Old 08-20-2006, 05:02 PM
Once Banned
cegodsey's Avatar
Sure thang, man. Mine wasn't real, but it sounds plausible, don't it?
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #9 of 16 (permalink) Old 08-20-2006, 05:11 PM
Search Goddess
Dianna's Avatar
No Cegodsey.. I got my waders out when I started reading yours *L*
Remember the story about the little boy that cried WOLF! Pretty soon no one believed him..
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #10 of 16 (permalink) Old 08-20-2006, 06:43 PM
Once Banned
cegodsey's Avatar
Haven't heard that one.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
