86 knocker is running - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-08-2012, 05:01 PM Thread Starter
Here's a video of the "knocker" running. You can hear the knock very well in it.
http://www.youtube.com/watch?v=s7-Ar...ature=youtu.be
Sometimes it sounded like the bottom end, but also sounded like the top end front at times. The rear cylinder seemed nice and quiet. I tried the grambo trick, and it didn't seem to help. I only turned the screw CCW about 1/4 turn. What to you guys think?
Jacknh is offline
post #2 of 10 (permalink) Old 07-08-2012, 05:31 PM
The cam chain could have slipped a tooth? Wolfie got his back in timing without an engine pull.
Have you used a screwdriver on it? Not that I advise running it really, but using a screwdriver as a stethoscope can help pinpoint the location.
post #3 of 10 (permalink) Old 07-08-2012, 05:46 PM Thread Starter
Yeah I did the screwdriver routine. Just can't seem to point it out. Maybe I should try to find a real stethoscope.
Think it's safe to rule out the ACCT, though?
Jacknh is offline
post #4 of 10 (permalink) Old 07-08-2012, 06:17 PM
It's way too loud to be an acct (unless it completely failed and your timing is off)
On the right, bottom side of the engine there is the water impeller. Maybe it's breaking down.
post #5 of 10 (permalink) Old 07-08-2012, 06:48 PM
Ouch, sounds like the crankshaft is shot. Complete rebuild needed if your going to keep it.
Rebel13 is offline
post #6 of 10 (permalink) Old 07-08-2012, 07:06 PM
that sounds just like what my 86 is doing
pritch1 is offline
post #7 of 10 (permalink) Old 07-08-2012, 07:18 PM Thread Starter
Okay, I'll look around for an engine and tear this one down and see exactly what we've got here. Thanks for the responses!
Jacknh is offline
post #8 of 10 (permalink) Old 07-10-2012, 05:49 PM
Check your valve train and see if a rocker has come off of the HLA, or one of the HLA's has collapsed.
TSmith68 is offline
post #9 of 10 (permalink) Old 07-12-2012, 08:45 PM Thread Starter
I've got the top end torn down (minus removing valves from the heads.) I see a lot of wear, but nothing to cause a slap like that. I'll post some pics tomorrow.
Jacknh is offline
post #10 of 10 (permalink) Old 07-22-2012, 11:35 PM
Did you find any more out? I got an '86 to work on and it has the same exact noise. I will be tearing it down this weekend but wanted to see if you could steer me in the right direction.
ConradCA is offline
