Coolant Leak here! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-02-2012, 11:38 AM Thread Starter
Glenn C.
gcextreme's Avatar
Coolant Leak here!
I just did a stator replacement, got the bike back together, and now have a coolant leak on the left side, top rear, coming from that black pipe/hose at the top.
Whats the best fix?
Glenn C
Alexandria, MN
My VN750 Page
VN750 Stator Plates and Products
2001 Kawasaki Vulcan VN750
1986 Kawasaki Vulcan VN750 (being restored)
1986 Kawasaki 454LTD (being restored)
1985 Kawasaki 454LTD (being restored)
gcextreme is offline
post #2 of 20 (permalink) Old 07-02-2012, 11:42 AM
See your other thread. :P
Unbolt and slide out the tube, gently. Replace the o-ring.
post #3 of 20 (permalink) Old 07-02-2012, 11:42 AM
there is an O-ring on that tube .... Re-seat or Replace.
WilliamTech
post #4 of 20 (permalink) Old 07-02-2012, 12:55 PM Thread Starter
Glenn C.
gcextreme's Avatar
Thanks guys.
Now my temp gauges seems to be not working. Its stuck all the way to the left at C, even after about 20 mins of riding today on a hot sunny day. It normally stays about mid way.
Glenn C
Alexandria, MN
My VN750 Page
post #5 of 20 (permalink) Old 07-02-2012, 01:07 PM
Is the little wire on the bottom of the engine connected? Super thin wire.
post #6 of 20 (permalink) Old 07-02-2012, 01:59 PM Thread Starter
Glenn C.
gcextreme's Avatar
Is it a green wire?
The fan is working, just not the needle/gauge.
Glenn C
Alexandria, MN
My VN750 Page
post #7 of 20 (permalink) Old 07-02-2012, 02:56 PM Thread Starter
Glenn C.
gcextreme's Avatar
Ok figured it out.
When I removed the tank to get at that hose to replace the o-ring, the wire up top on the radiator hose housing must have came off.
Plugged it back in, it works lol.
The last few weeks have been one issue after another.
Dead battery, fried stator and r/r, tear apart and remove the engine, replace stator and r/r, put back together, do coolant and lubes, then end up with a coolant leak, and then a busted travel trailer I had to hurry up and get fixed, then this thermostat gauge issue.
Now I should be ready to hit the road on my vacation ride to Algona Iowa for the big biker freedom rally!!
Glenn C
Alexandria, MN
My VN750 Page
post #8 of 20 (permalink) Old 07-02-2012, 03:26 PM
Let's Ride!!
DaveT319's Avatar
I've got a little leak there too. Is that O-ring special in any way? Could I just go with a same size replacement from Ace or something?
And where is the wire you are talking about? I thought the temp gauge sensor what near the radiator cap. Or are there multiple sensors? Mine also reads very low ever since I replaced the engine.
DaveT319 is offline
post #9 of 20 (permalink) Old 07-02-2012, 03:29 PM Thread Starter
Glenn C.
gcextreme's Avatar
My local kawi dealer had then in stock, 60cents each.
The wire I had disconnected was up by the radiator cap. But I think there's another on underneath at the back of the engine.
Glenn C
Alexandria, MN
My VN750 Page
post #10 of 20 (permalink) Old 07-02-2012, 03:33 PM
Let's Ride!!
DaveT319's Avatar
OK, I'll look, but was pretty sure I had reconnected everything.
DaveT319 is offline
