complete loss of power at high speed low rpm - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-27-2012, 02:59 PM Thread Starter
Well like the title says I lose it almost dies Ans will die if I pull in the clutch in anything after 2nd gear. Acts like poogs but its all clean and new and makes no difference. If I go high rpm its fine. Any clues?
loud75088 is offline
post #2 of 6 (permalink) Old 06-27-2012, 03:45 PM
Crap, I WAS in 5th gear.
Could be clogged pilot(s) in the carb(s). Your description isn't fully consistent with this though.
Kelly2001 is offline
post #3 of 6 (permalink) Old 06-27-2012, 04:00 PM
ifixf18s's Avatar
How does it idle ? Can you run up the throttle and sounds ok? I had a simular issue with mine, try to give it gas and it bougs down. But my bike sat awhile. I used 1/2 can of seafoam in a freash tank of gas and it cleared up.
ifixf18s is offline
post #4 of 6 (permalink) Old 06-27-2012, 05:02 PM Thread Starter
It idles perfect. Carbs are clean, tank Is clean, gas is new, non ethonol. Runs through the entire rpm band perfect with no load, if I give it hell it runs perfect, but if I try to cruise it bogs down, then I can work the throttle open and closed and get to a lower gear and its five again until I try to cruise again. I just put a new gas cap on today too, and cleaned the system. It doesn't do this everytime. But 8/10 rides it will. Just started this two days ago, carbs were cleaned two weeks ago, and then again today. No change.
post #5 of 6 (permalink) Old 06-27-2012, 10:31 PM Thread Starter
Fixed It. Bowl vent tube came out and I didn't notice it. It was catching wind.
post #6 of 6 (permalink) Old 06-27-2012, 11:57 PM
Came to suggest this. Nice catch!
