need an engine - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-25-2012, 06:41 AM Thread Starter
BeeSea's Avatar
need an engine
I was riding down the back roads and heard a loud clacking noise, the noise got worse so turned for home. About 2 miles out from home the back wheel started getting shiney...yup the oil was coming out something furiously like...pulled over and the rest bleed out of the crank case.... Think I need a new engine.
But not really savvy about these things. Anyone got a spare engine for a 1986 Vulcan??? I really love my bike and would hate to have to get another.
Thanks.
BeeSea is offline
post #2 of 11 (permalink) Old 06-25-2012, 09:59 AM
I would do a full inspection to see if you maybe lost an oil bolt. It is possible you turned off the engine prior to perm. damage.
The good news for you engines from 86-2006 will work. The bad news is with any engine purchase, you don't know how well the engine was maintained.
post #3 of 11 (permalink) Old 06-25-2012, 09:14 PM
Concert connoisseur
wib714's Avatar
how many miles were on it, pull the screen like your gonna do an oil change and see if there are any flakes or rubber chunks in it!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 11 (permalink) Old 06-26-2012, 01:47 PM Thread Starter
BeeSea's Avatar
only 25,000 just broke it the other day. Will work on cleaning it up this weekend and see what could really be the problem. I was just so bummed all that oil leaking out...
will keep you updated.
BeeSea is offline
post #5 of 11 (permalink) Old 06-26-2012, 02:40 PM Thread Starter
BeeSea's Avatar
oh and thanks for the heads up on which year of engines will work, I will definately look to see if there is metal shavings before I go ordering a motor.
BeeSea is offline
post #6 of 11 (permalink) Old 06-27-2012, 08:07 PM Thread Starter
BeeSea's Avatar
Ok here is the hole and there was metal shavings in the oil, very fine metal shavings -didn't see any rubber pieces. My husband says it felt like the chain was very loose in the hole. We were thinking it was the clutch or shift leaver or something like that. We will have to tear it completely apart to find out. Unless you have some other suggestions for diagnosis. Thanks.
ID:	4652   Click image for larger version
ID:	4653   Click image for larger version
BeeSea is offline
post #7 of 11 (permalink) Old 06-27-2012, 09:37 PM
The left side of the front cylinder casing has the chamber where the upper and lower camshaft timing chains live. It must be the lower timing chain your husband can feel through that hole.
http://www.bikebandit.com/houseofmot...50137#sch50864
Also see part 4 of Roach`s engine teardown (for the front cylinder, left side cam chains etc.):
https://www.vn750.com/forum/showthread.php?t=18289
post #8 of 11 (permalink) Old 06-28-2012, 03:12 AM
Let's Ride!!
DaveT319's Avatar
Yeah, if you are curious you can try to track down what went wrong, but the bottom line here is that you will indeed need a "new" engine. That is in no way repairable. I know from experience that it's painful when your baby dies. But the good news is that with some work it can be brought back to life. Good luck.
DaveT319 is offline
post #9 of 11 (permalink) Old 06-30-2012, 06:58 AM
1985 VN-700
L2fish's Avatar
Look on EBAY, buy it, rebuild it, ride for another 20 plus yrs
L2fish is offline
post #10 of 11 (permalink) Old 06-30-2012, 10:46 AM
I just fixed one that the balancer gear bolt backed out. The damage was not that severe as yours. I used epoxy to seal the block. You are going to need another engine or at least the block halves.
