Oil Leak Help!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-22-2012, 08:18 PM Thread Starter
Exclamation Oil Leak Help!!
Hey guys,
I just bought my bike and am noticing a few drops of oil leak after every ride from the oil drain plug. At least, I think its the drain plug. Its right under the bike beside the kickstand. Anyway, if that's the leak, do I just need to put a new gasket or something on the plug? If so what size and were do I buy it? I'm planning on changing the oil tomorrow anyway and would like to get this leak taken care of!
Thanks in advance!
jon13700 is offline
post #2 of 11 (permalink) Old 06-22-2012, 08:29 PM
First check to see if it is tight. There is an o-ring on it.
Rebel13 is offline
post #3 of 11 (permalink) Old 06-22-2012, 08:34 PM
JM2001's Avatar
Also check the threads, could be stripped from overtightening or cross threaded
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 11 (permalink) Old 06-22-2012, 09:37 PM Thread Starter
The plug is tight. I just got back from a ride and the drip is coming like an inch more towards the rear by another small nut or something. Any ideas!!?
jon13700 is offline
post #5 of 11 (permalink) Old 06-23-2012, 12:07 AM
'03 VN750 "Rosie"
bstew7890's Avatar
Perhaps it's blowing back from the drain plug during the ride? I would plan on running out for a new o-ring after you pull the drain plug; chances are its damaged. And make sure it's not over tightened or cross threaded.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #6 of 11 (permalink) Old 06-23-2012, 08:27 AM
Are you referring to the oil drain with the screen on the side down low on the engine or the drain plug that threads straight up in to the crankcase?
These bikes have 2 drain plugs and the nut you are referring to may be the other drain plug.sounds like you need to buy an oil change and drain the oil and drain it and check both plugs and the seals.I think one has a sealing washer and the one with the screen has an o-ring,don't overtighten either.You can strip the aluminum threaded holes in your cases.
post #7 of 11 (permalink) Old 06-23-2012, 09:14 AM
Hey guys,
Thanks in advance!
Denny, from the opening post jon describes the side drain plug behind the sidestand.
jon, the bolt located an inch behind the drain plug is one of 6 or 7 holding the side cover on the bevel gear case. Put a wrench on it and see if it is loose.
But I tend to agree with the idea that the O-ring on the drain plug is damaged.
link to diagram:
http://www.bikebandit.com/houseofmot...50137#sch50086
92055B: RING-O 11028-1099 864896 $4.82
You can probably just take the drainplug to a hardware or automotive store with a good selection of O-rings, and pick one to fit.
post #8 of 11 (permalink) Old 06-23-2012, 09:57 AM
What he said x2^,I missed the part about beside the side stand,looked at that to early I guess
post #9 of 11 (permalink) Old 06-23-2012, 11:03 AM Thread Starter
Thanks for all the help guys! I got called in to work the next few days so I'll just have to keep an eye on the oil level until I can fix it! It isn't leaking more than a few drops after the bike is turned off so I should be good for a few days!
jon13700 is offline
post #10 of 11 (permalink) Old 06-23-2012, 06:18 PM
Model A Guy
Jeff Barnes's Avatar
Oil leak
Could be the rubber gromet that seals the electrical wires coming from the stator. I used black RTV to seal mine as the rubber gromet was gone.
This was my several drops of oil (after every ride) leak and now I have none.
I used several paper towels to trace the leak, starting at the drips, up the left side of the engine. If you have a small inspection mirror it will help with putting the sealant around the opening where the wires come out of engine. Clean the opening and wires before aplication of the RTV. Just another possibility!
Jeff Barnes is offline
