Throttle response - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-21-2012, 08:22 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Throttle response
I've noticed for a while that when I rev the throttle while in neutral, the revs take a few seconds to come back to idle. Like if I rev it up to about 5k, it takes about 3-4 seconds to come back to 1k. I notice that with most other bikes, it's much faster, like a second or so. I only became aware of it in the last few months, but for all I know it may have been going on the entire time I've had the bike. Is this normal for the Vulcan, or is there something going on with my carbs and/or throttle cables?
DaveT319 is offline
post #2 of 12 (permalink) Old 06-21-2012, 09:51 PM
Mine drops pretty fast. It could be somewhat lean causing it to be slow on deceleration.
Mine was hanging up a bit, but I am not sure what I did to fix it. I retightened all the boot clamps, etc.
Make sure you have no cracks in the carb boots, or airbox. Make sure the air filters are in good condition, etc.
post #3 of 12 (permalink) Old 06-21-2012, 10:16 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
The filters are new from when I put in the motor. I think the boots are all fine, but I'll check them to be sure.
DaveT319 is offline
post #4 of 12 (permalink) Old 06-21-2012, 11:12 PM
let me know what you come up with. i have the same problem with mine. i adjusted the air fuel mixture screws and it didn't fix the problem. everything is tight and nothing is damaged. not sure what the problem is either
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
- Stereo with 3.5 inch speakers
- Sylvania ridiculously bright headlight
- Westco maintenance free battery
- Vance & Hines slash cut pipes
- Custom turn signal bracket
- Arrowhead universal turn signals (rear only)
- Kuryakyn longhorn offset highway pegs
- Suzuki Savage 650 rear shocks (2 inches shorter)
- Lowered front 1.5 inches
drfraser is offline
post #5 of 12 (permalink) Old 06-22-2012, 01:42 AM
Crap, I WAS in 5th gear.
Check your coasting enrichers.
Kelly2001 is offline
post #6 of 12 (permalink) Old 06-22-2012, 01:50 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
Check them for what?
DaveT319 is offline
post #7 of 12 (permalink) Old 06-22-2012, 08:07 AM
Tiny Elves.
post #8 of 12 (permalink) Old 06-22-2012, 09:14 AM
TH didn't yours get better after you did the work on the T connection for the petcock??
Swagman is offline
post #9 of 12 (permalink) Old 06-22-2012, 10:35 AM
are the carburetors synchronized?
If your air/fuel screws are too lean it will be slow to drop RPM's.
I had similar issue and it turned out that the sync was off and the front carb was set too lean.
as mentioned above....check for air leaks in the vacuum system and carb boots...and chase away the tiny elves
post #10 of 12 (permalink) Old 06-22-2012, 05:11 PM
Stones750's Avatar
Try to turn your idle adjuster (black knob on left side) counter clockwise a little at a time then rev...does it go back to idle quicker or still hang? If its set to far clockwise on mine it will do the same thing and drop rpms slowly.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
