cooling system - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-20-2012, 08:23 PM Thread Starter
cooling system
my expansion tank is over pressurizing. whats up? also fan isnt coming on
roadster97 is offline
post #2 of 4 (permalink) Old 06-20-2012, 08:55 PM
The above bike has had the thermostat replaced and a flush a fill, but still overheats on hot days.
Sweetdancer57 is offline
post #3 of 4 (permalink) Old 06-20-2012, 09:51 PM
romeobravo172
romeobravo172's Avatar
Fan not coming on is a clue!!!!! Air in system-clogged radiator--thermo switch on bottom of rad is a good start! You can at least bypass that to get fan working.
romeobravo172 is offline
post #4 of 4 (permalink) Old 06-20-2012, 11:55 PM
That thermo switch on the lower left side of the rad, is a ground back to a relay I believe, in the junction/fuse box under the left side cover.
Pull the connector off and inspect for corrosion or damage.
Slide it on and off a few times to mechanically clean it.
Try grounding the connector on the wire with an additional jumper wire to bare metal or the negative battery terminal to determine if the fan works.
If the fan works with a good ground, the thermo switch likely needs replacing.
Then spray with some electrical contact cleaner, and pack the connector with a dab of dielectric grease to prevent future corrosion.
