coil mod gone bad: please help! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-20-2012, 07:49 PM Thread Starter
Question coil mod gone bad: please help!
so i was doing the coil mod (file the bracket to get it closer to the rotor) and the wires came off! ill need to get a new one, but looking in the service manual, it is not called a coil, nor can i find the part looking thru the pictures. any ideas?
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
- Stereo with 3.5 inch speakers
- Sylvania ridiculously bright headlight
- Westco maintenance free battery
- Vance & Hines slash cut pipes
- Custom turn signal bracket
- Arrowhead universal turn signals (rear only)
- Kuryakyn longhorn offset highway pegs
- Suzuki Savage 650 rear shocks (2 inches shorter)
- Lowered front 1.5 inches
drfraser is offline
post #2 of 12 (permalink) Old 06-20-2012, 07:57 PM
Don't they have a plastic connector that clips on?
Part # 59026-1062 (COIL-PULSING)
Found some here for $26+shipping.
post #3 of 12 (permalink) Old 06-20-2012, 09:25 PM Thread Starter
that is exactly what i was lookin for. wasn't wanting to run all new wire, but i guess i gotta do what i gotta do. where does the connector end connect at? i tried following the wire on the bike but it got too tight and i couldn't see where it lead to
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
drfraser is offline
post #4 of 12 (permalink) Old 06-20-2012, 09:48 PM
It goes to the igniter unit, near the battery.
post #5 of 12 (permalink) Old 06-20-2012, 10:41 PM Thread Starter
another question i just thought of... when i run the connector/wires from the inside of the engine to the outside, will i have to take the stator cover off to? that pretty much requires an engine removal doesn't it?
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
drfraser is offline
post #6 of 12 (permalink) Old 06-20-2012, 11:27 PM
Someone here, (maybe slimvulcanrider?), had a wire come off the pickup/pulse coil too.
He was able to solder it back on and save the cost of a new one.
It is an option if you can solder, or have a buddy who can.
post #7 of 12 (permalink) Old 06-20-2012, 11:43 PM Thread Starter
didn't even think of that one! already got my new ones ordered though, so ill just do the mod on those. then i'll just have to figure out how to run the wires to the ignitor. the manual says to remove the engine and the stator cover, but i REALLY don't want to do that if i can avoid it. any suggestions?
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
drfraser is offline
post #8 of 12 (permalink) Old 06-21-2012, 12:36 AM
It could be fairly difficult to fish them through.
post #9 of 12 (permalink) Old 06-21-2012, 10:10 AM
I would try to tape the new one to the old and pull it through first. As long as there isn't a tight bend or its cinched down somewhere that might work.
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #10 of 12 (permalink) Old 06-21-2012, 01:04 PM
You can't simply feed them thru. They fit behind a bend on the inside of the cover. You will have to take the cover off to route them properly. The connection end has a connection close to the battery box. It simply disconnects & plugs in the new one. You also don't have to fully remove the engine. Look up the "tilt" process. You almost remove the engine but really just tilt it enough to get the the bolts that are obstructed by the frame.
