How paranoid am I? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-19-2012, 10:22 PM Thread Starter
How paranoid am I?
So i have been having a slight knock that i have been trying to track down. Along with that i have been having what sounds like a grinding noise when i on the throttle. i have changed over to mcct's seeing if that remidied the problem. Did not change anything. Today i changed the oil to see if there was any metal particles, but once again nothing. It sounds like it is coming from the front bottom of the case.
I know the balancer is down there, but like i said no plastic or metal coming from the oil.
So like the heading says. Am i just worrying over nothing, or am i hearing the beginning of the end of my balancer or some other part.
Thanks Mick.
Mick51 is offline
post #2 of 5 (permalink) Old 06-19-2012, 11:03 PM
If it is coming from the right-bottom of the engine it could be the water impeller. To my understand it is a fairly easy fix, and doesn't require an engine pull.
Edit: Change? what was I thinking.
I'm doing mine soon. It makes noise, but has since I got the bike.
post #3 of 5 (permalink) Old 06-20-2012, 10:58 PM Thread Starter
Ill have to do some research on that one. Never even thought of that. I take it that its not to big of a deal since youve had the noise for awhile. Is there a way to check that. Thanks mick.
Mick51 is offline
post #4 of 5 (permalink) Old 06-20-2012, 11:06 PM
Daily rider
ksmnet's Avatar
How's your battery. I had something similar happen, and it would even die on me. I read somewhere that if the battery is weak it can cause all sorts of issues with the bike running. I changed the battery, and no more problem.
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
post #5 of 5 (permalink) Old 06-21-2012, 12:40 AM
You need to pull the stator cover. It's a $50 or so operation I believe.
Code:
Kawa Part # 	Ref #	Description
59256-1058 	59256	IMPELLER
670D1509 	670A	O RING,9MM
11060-1090	11009C	GASKET,CLUTCH COVER
49063-1057	49063	SEAL-MECHANICAL
Subtotal: $59.40 (RonAyers)
