Cooling fan motor thermo sensor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-19-2012, 11:16 AM Thread Starter
I was cleaning my electrical connections today and the prong broke off the thermo sensor. i can buy a new one for 85$ but was wondering if there were any cheaper option "aftermarket" or what ever
1991 VN 750
Mortagleus is offline
post #2 of 6 (permalink) Old 06-19-2012, 02:32 PM
Check for used ones on eBay.
post #3 of 6 (permalink) Old 06-19-2012, 05:04 PM
I found one here on the forum. If I had not found one I was going to solder a wire to the the sensor. And hope for the best.
post #4 of 6 (permalink) Old 06-19-2012, 05:23 PM
romeobravo172
romeobravo172's Avatar
A few here have added a switch to turn fan on and off physically. Maybe that would be an option until you find the part!
romeobravo172 is offline
post #5 of 6 (permalink) Old 06-19-2012, 05:47 PM
romeobravo172
Ck with Tofer76 he may have one!
post #6 of 6 (permalink) Old 06-19-2012, 06:00 PM
I had the same experience when cleaning electrical connections. MaKaw for $85.00 or...... I drilled a hole in the remains of the broken stud and soldered a wire with another electrical terminal. Wire broke off after a few months. So then i just wired it to a switch, mounting the switch in the left (black) cowling/handlebar/frame cover. Works perfectly, just a slight lean forward to turn on.
Hope this helps
Good luck
WilliamTech
