Possible Gasket leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-12-2012, 11:00 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
I'm wondering if I have a problem here and, if so, how serious. This pictures were taken right after a 600 mile weekend trip. I added about 1/4 qt. of oil when I reached my destination after I checked the oil and noticed it was around the middle of the sight glass. I thought it had just burned some off during the highway riding; I was going 80 mph or better most of the way. I think the oil on the bevel gear case could be blowback from the clutch cable.
I would love to hear your thoughts!
Thanks!
ID:	4603   Click image for larger version
ID:	4604   Click image for larger version
ID:	4605   Click image for larger version
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 7 (permalink) Old 06-12-2012, 11:12 AM
You don't seem to have a leak. You were probably riding in hot weather and at a fast pace. This may cause your bike to use a little oil. Make sure to keep it full. If you run it low it may cause your stator to fail. MO
post #3 of 7 (permalink) Old 06-12-2012, 12:18 PM
What he said X2
wipe the dirt and oil off your engine and see how long it takes to get dirty again.I have found with a minor oil weep if you don't disturb it,Things usually don't get worse,it may not be worth the hassle.Use some kind of spray cleaner like brake kleen or even starting fluid to make sure to get rid of whatever residue is on the engine and collecting road grit.
How long since your last oil change ? you may have not gotten quite full or it may be that it used that amount over time.
post #4 of 7 (permalink) Old 06-12-2012, 01:00 PM
Crap, I WAS in 5th gear.
That is not much of a leak at all. I have to park over a drip pan. I need to re-seal my stator cover after the mod, because I cut the new wire exit a little too big for the grommet and it is leaking. It was dripping before, but my threshold has been crossed now- more than one drip on the ground after sitting.
Kelly2001 is offline
post #5 of 7 (permalink) Old 06-14-2012, 01:37 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
Thanks everyone. Glad it's not a big deal. I'll probably just clean it with a degreaser and toothbrush and ride on!
'03 VN750 "Rosie"
Lubed Splines
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
post #6 of 7 (permalink) Old 06-15-2012, 10:31 AM
tooth brushes are an awesome cleaning tool go buy a new one for the wife (don't let her know) then let her find you using her old one to clean your engine. lol keep the new one close by!
1991 VN 750
Mortagleus is offline
post #7 of 7 (permalink) Old 06-15-2012, 11:31 AM
gun slinger
centurynick's Avatar
mine seeps from that spot
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
