How to replace fan switch? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-13-2006, 11:05 PM Thread Starter
My 750 has been overheating. I believe it is the fan switch. The fan has not been kicking on. I direct wired fan to frame and fan worked. Can someone tell me how to replace switch? If you think there might be another issue please let me know your thoughts. I'm very new at this. Thanks in advance.
Crab is offline
post #2 of 3 (permalink) Old 08-13-2006, 11:34 PM
Once Banned
cegodsey's Avatar
I don't know about the switch, but I did a search in the forum and found that the relay is in the junction box. In the shop manual, it says to disconnect the wire from the fan switch (radiator, lower left side), and ground it to a bolt on the frame. If the fan kicks in, then it's the switch, otherwise it's the junction box. Just looking at it, you'll need to drain the coolant to take the switch out. Let us know what you find out.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 3 (permalink) Old 08-18-2006, 01:24 PM
Loran in Npvl IL's Avatar
You don't really NEED to drain the coolant to replace the switch, just be fast with the replacement then check the coolant level after each ride for the next week or so.
However, you should drain & change the coolant if you haven't done it in a while (or don't know when it was last done).
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
