Oil Screen Cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-31-2012, 03:10 PM Thread Starter
Stones750's Avatar
Oil Screen Cap
So when I bought my vulcan it was in rough shape, until now I have been changing the oil through the drain bolt but really want to clean the screen assembly. The PO had stripped the heck out of it to the point it is no longer a nut but more like a clean circle...anyone out there have any tips to get this off? I tried PB blaster and vice grips but it won't budge-any advice would be greatly appreciatted.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #2 of 8 (permalink) Old 05-31-2012, 03:29 PM
You can file two of the sides flat so you can get a good wrench on it. That should probably do it.
post #3 of 8 (permalink) Old 05-31-2012, 03:52 PM
Might be a little hard getting a file in there . A dremel tool with grinding/sanding drum works faster. Get two opposite sides flat, muscle on a big pair of vise grips and use a cheater bar through the vise grips to do the twisting.
post #4 of 8 (permalink) Old 05-31-2012, 03:53 PM
I need to get one for my tool-kit. I keep doing things the hard way :P
post #5 of 8 (permalink) Old 05-31-2012, 04:46 PM
sparkingdogg's Avatar
use the dremel tool to cut a straight slot in the center, and use a hand impact driver with a tip that fits the slot well, i guarantee it will come right out with less than 5 minutes work. i have removed a hundred bolts and such with this technique and don't even bother to try any other method. just my two cents, but i tear down bikes for a living and have had a lot of stripped stuff over the years. if it is really tight, torch the motor case for about 30 seconds, keeping the torch moving. it will make the metal expand and aid with removal. a propane torch is all you need, or a heat gun would even work.
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #6 of 8 (permalink) Old 05-31-2012, 05:07 PM Thread Starter
Stones750's Avatar
Thanks guys for all the tips- thtanner definately get a Dremel I wasn't sure I needed one at first but it's become one of my favorite tools. I'm a little ashamed I didn't think about the file tip lol I'll give that a shot since the only torch I have is MAP gas. Now I hope I dont find any ugly suprises in there, thanks again and ride safe.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #7 of 8 (permalink) Old 05-31-2012, 07:36 PM
Same here....I used a pair of vise-grips (curved jaw) to get it off, then took a file and made it a non metric size....its alloy, so files easily. I can put a box wrench on it now no prob. No need to buy new. Big thing is to not overtighten when reinstalling. Some people overtighten oil filters too.
post #8 of 8 (permalink) Old 05-31-2012, 07:48 PM
Use a bolt out.
Rebel13 is offline
