crush gaskets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-30-2012, 09:56 PM Thread Starter
pittdave's Avatar
crush gaskets
Are the crush gaskets toast after they are installed and any exhaust changes need to be done?? I.E. If you install new pipes and then and few days later the pipes need to come back off, is that gasket now ruined and it needs to be replaced or am I still good for a while?
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 3 (permalink) Old 05-30-2012, 10:37 PM
JM2001's Avatar
You should replace them or you will probably have exhaust leaks.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 3 (permalink) Old 05-31-2012, 01:44 AM
Ndr
*SHOULD* replace them. However, with that short of a time span, you might be able to get away with it. If you happen to get an exhaust leak after reinstalling the pipes, then really all it ends up costing you is the extra time of having to remove the exhaust again. Which isn't all that hard when you've been degoated.
Ndr is offline
