Balance Dampers Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-18-2012, 08:48 PM Thread Starter
Ceal's Avatar
I just read another post about vibrations... didn't want to be accused of thread jacking, so here's a new one. Although now I may be accused of starting a new thread for no reason lol.
Imagine your balance dampers (or dampeners, don't know which is the right word) go out and start to disintegrate... you should notice this when you change the oil, by seeing small pieces of plastic in the oil screen.
Now, imagine that you pay no attention to it at all and just keep riding and doing oil changes.
Is there a point when there will be no more plastic bits in the oil screen at all and the bike is still ride-able?
I ask because my bike isn't smooth at all, plus it has a certain clanking sound. I've suspected the balance dampers, but I've never seen plastic bits in the oil screen on any oil change. No plastic bits and no metal shavings either.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #2 of 14 (permalink) Old 05-18-2012, 09:27 PM
I would imagine the dampers still could be bad. They can also shrink, and not break apart, which can cause the vibration/noise.
Edit: May want to get manual cam chain tensioners to eliminate cam chain noise as the knocking/clacking.
post #3 of 14 (permalink) Old 05-18-2012, 11:36 PM
I also (as above) imagine that the damper are going.
post #4 of 14 (permalink) Old 05-19-2012, 02:46 AM Thread Starter
Ceal's Avatar
I do WANT to get them, I just don't have the cash for them lol
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #5 of 14 (permalink) Old 05-19-2012, 02:49 AM Thread Starter
Ceal's Avatar
I should probably just take the engine out and rebuild it... but last time I was looking at parts, it was over $500 and I just stopped looking.
Might have to investigate just how much money I'd need for a rebuild. An engine from 85 should need a rebuild by now.
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #6 of 14 (permalink) Old 05-19-2012, 03:26 AM
Changing balance dampers took me less than an hour after the engine was out. A rebuild is going 100 steps further than you need to, so just do the dampers and stator if needed.
post #7 of 14 (permalink) Old 05-19-2012, 03:42 AM
Since you were so kind not to hijack my thread, how about I hijack yours!
Quick question: Are there any shortcuts to doing this job? Can you remove the engine mounts and just shift the engine, or do you really need to remove the whole thing?
'86 VN750
Pickup coil mod
Iridium plugs
New CDI Ignitor
Clutch Basket Mod
Nebraska68 is offline
post #8 of 14 (permalink) Old 05-19-2012, 07:49 AM
There was no way that I could of done that job without engine removal. I did hear of some one doing it with the engine tilt.
post #9 of 14 (permalink) Old 05-19-2012, 10:36 AM
gun slinger
centurynick's Avatar
ceal you said your s has a " clacking " noise is this all the time or at a certain rpm?
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #10 of 14 (permalink) Old 05-19-2012, 12:05 PM
Agreed. By the time I got the engine to a point where it could be tilted, it was only an extra 10 minutes to get it completely out. Would have been pointless to try to just tilt it.
