tocmanufacturing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 05-16-2012, 10:26 AM Thread Starter
tocmanufacturing
website is so outdated is this a safe place to buy ? looking for MCCT http://www.tocmanufacturing.com/Manu...nTensioner.htm
yoshi is offline
post #2 of 20 (permalink) Old 05-16-2012, 10:39 AM
Yahoo VN750 Group Owner
Pick's Avatar
Send a message via Yahoo to Pick
Yes it is. James Larson is the man, and his stuff is good!
Jim "Pick" Foster
Dixon, IL
VROC #9492
2018 Suzuki Burgman 650
2010 Honda NT700V
http://www.flickr.com/photos/jimfost/sets/
http://s186.photobucket.com/albums/x294/jimfost/
Pick is offline
post #3 of 20 (permalink) Old 05-16-2012, 10:44 AM Thread Starter
thanks
yoshi is offline
post #4 of 20 (permalink) Old 05-16-2012, 11:57 AM
JM2001's Avatar
The manual cam chain tensioners are good. The acct replacement springs and rebuild kit are a different story.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 20 (permalink) Old 05-16-2012, 01:47 PM
2000 VN 750 Senior Member
Originally Posted by JM2001 View Post
The mechanical cam chain tensioners are good. The acct replacement springs and rebuild kit are a different story.
Could you explain a little bit more as I am about to do my Vulcan in the next week or two and I going to contac TOC today or tomorrow for parts.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #6 of 20 (permalink) Old 05-16-2012, 02:16 PM
JM2001's Avatar
The complete manual cam chain tensioners are well built and work well. You could save a lot of money and do the mcct conversion described on this forum. The acct springs and rebuild kit from TOC are not worth the money and do not solve the problem. Their springs are not much heavier than the factory ones. I replaced my acct springs with 9000 miles on them with the new ones and you couldn't tell the difference between the two. I took them out in 5 minutes because the noise was the same and did the mcct conversion. TOC was good to do business with but I feel the replacement springs aren't worth it and doing a mcct conversion is the only way to go.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #7 of 20 (permalink) Old 05-16-2012, 02:25 PM
Viking
I got the MCCT and mounted them just recently - they are high quality build, and simple to install and adjust. Can only recommend them.
Best regards from Denmark
Torben Wallner
87 vn750
Black colored (black bikes are the fastest ones)
BOS exhaust
TOC's
Sissybar removed
Splines lubed
facebook: www.facebook.com/TorbenWallner
towa is offline
post #8 of 20 (permalink) Old 05-16-2012, 07:06 PM
Acolytes of Perdition
beeblebrox82's Avatar
yep, just got my TOCs recently. fast and easy.
beeblebrox82 is offline
post #9 of 20 (permalink) Old 05-16-2012, 08:05 PM
I was skeptical myself since I have an 06 with low miles....but I now have them and they are beefy, well made, easy to install....and you won't believe how quiet it makes the engine.
They are worth the money IMO
post #10 of 20 (permalink) Old 05-16-2012, 08:07 PM
Patriot Guard Rider
The DEUCE's Avatar
TOC is totally safe and secure.
VN750 #9300 & VROC #33453
The DEUCE is offline
