Grrr ... Broken Exhaust Stud - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-14-2012, 08:47 PM Thread Starter
Well ... when Vulcan #1 died, I went out and got another one. Had it one the road right away and was enjoying it.
Was changing the fluids, moving the accessories from #1 over to #2, and generally just having fun with it. Even put approx 900 kms on it on the weekend without any issues (other than a tank of bad gas ... still waiting to see if my girlfriend's ZN750 survived her bad tank).
Tonight, after changing the final drive gear oil, I thought it would be nice to move the engine guard from #1 over to #2 (since #2 didn't have one). The guard came off relatively easily, only a little "wiggling" required to get it off the bike, and the one bolt out past the exhaust.
Putting it on #2, that's where things went wrong. It became obvious right away that more than a little "wiggling" would be required to get the one bolt on past the exhaust. No big deal I thought ... I will just loosen off the header to give me some more "wiggle room".
Well ... you guessed it ... as I twisted one of the nuts, rather than loosen ... it broke the stud right off !!
Will have to call the dealer tomorrow and order some more new parts (studs, gaskets, nuts) and then see what I can do about getting the rest of the stud out.
#1 - 1986 Vulcan 750
Purchased Jan of 2012 w/ 41,000 kms
On the road as of April 4
Unfortunately, after third ride (300 km) ... horrible engine noises ...
XXXXX FOUND METAL IN OIL SCREEN XXXXX
#2 - 1993 Vulcan 750
Purchased May 4, 2012 w/55,000 kms
On the road in only 4 days with no major work required
Have moved most of the accessories from #1 to #2
SnakeMurphy is offline
post #2 of 6 (permalink) Old 05-14-2012, 09:12 PM
romeobravo172
romeobravo172's Avatar
Sorry dude!!! I cheated on mine, think I have that same guard, you are talking about the right header exaust that has to be loosened to get the bolt behind off for the mounting bracket on the guard, the bracket that has the large nut on it, holds that piece to the guard. I said screw this and took a metal cutting wheel to the lower bolt hole and made it a slide on, can be done two ways, straight up from botton or from a 90degree angle. Makes install less painful, and cant tell it is any different!
romeobravo172 is offline
post #3 of 6 (permalink) Old 05-15-2012, 07:16 PM Thread Starter
Well ... after going back down to the bike today, it became pretty obvious that there was no way I'd be able to get the studs out of the manifold with the manifold on the bike.
So off came the rad and fan (after draining it). Not really an issue, since I was planning to change the coolant anyways.
So with the rad off, I soaked the manifold studs and nuts with PB Blaster (several times) and left it to stew. Will probably hit them again with PB Blaster tomorrow (and maybe even once more after that) I really don't want to break off the ones going into the cylinder.
Maybe after a few days of soaking with PB Blaster they will come right off ...
post #4 of 6 (permalink) Old 05-15-2012, 08:50 PM
sparkingdogg's Avatar
it works miracles, i also like to torch them red hot and quench them in pb blaster, between a torch and the blaster you will get them. i hope! and some used manifolds probably aren't too much, on ebay (i sold some on clearance a year ago for $20 shipped). good luck man!
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #5 of 6 (permalink) Old 05-16-2012, 10:53 PM Thread Starter
PB BLASTER WORKS WONDERS !!!
3 of the four cap nuts on the exhaust manifold came off without any issues at all. The 4th turned just as easily, but it turned out the actual stud. Not a big deal ... it's easy enough to put in a new stud.
Now I just have to put the manifold on a bench and get the broken studs out (I left them soaking with more PB for the night).
post #6 of 6 (permalink) Old 05-16-2012, 11:32 PM
PB Blaster is some good stuff. I also use it to wipe down my forks. It also will help to keep the rubber seals and wipers from drying out and cracking.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
