"misses" when riding into the wind? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-12-2012, 03:04 PM Thread Starter
Question "misses" when riding into the wind?
so, when i ride into the wind (and sometimes not) my bike will "miss" sometimes. not all the time, just sometimes. if i roll on the throttle, it works its way out of it... for a bit. it comes when it wants to and goes away when it wants. just can't make sense of it. any ideas?
drfraser is offline
post #2 of 9 (permalink) Old 05-12-2012, 03:30 PM
Check to see where the vacuum pipe is that runs under the tank from the carb, it runs forward and should go in to the right ear if you are still stock, if the wind catches this pipe then it cause a vacuum in the carb and makes it run poorly,so if it is not in the right ear push it back in but cut the pipe to a angle to stop it bottoming out and blocking up in the ear
Swagman is offline
post #3 of 9 (permalink) Old 05-12-2012, 03:35 PM
x2
post #4 of 9 (permalink) Old 05-13-2012, 02:16 AM Thread Starter
ok, guess by big question is: what is the "ear" you speak of?
drfraser is offline
post #5 of 9 (permalink) Old 05-13-2012, 02:22 AM
The right airbox
post #6 of 9 (permalink) Old 05-13-2012, 11:30 PM Thread Starter
well i had both the air boxes off a little while ago and there was no hose running to it, so that's probably the problem. something to check out tomorrow i guess. i'll keep you posted
drfraser is offline
post #7 of 9 (permalink) Old 05-13-2012, 11:56 PM
The hose to look for is a hose that "T" off from the carbs.
post #8 of 9 (permalink) Old 05-13-2012, 11:59 PM
Patriot Guard Rider
The DEUCE's Avatar
VN750 #9300 & VROC #33453
The DEUCE is offline
post #9 of 9 (permalink) Old 05-14-2012, 01:29 AM
Originally Posted by The DEUCE View Post
If you finD the hose you can zip tie it up under the tank out of the airflow if you want and i put a lawn mower fuel filter in the end of mine to keep it clear from debris,Dirt daubers and the like. All you are looking to do is get it out of the direct airflow and stop the flop.
