another MCCT conversion question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-12-2012, 02:48 PM Thread Starter
pittdave's Avatar
I seen a lot of the posts on converting to MCCTs, but I am getting the TOC MCCTs next week. What I haven't seen is if there is anything involved in taking out the stock ACCTs. Do they come out in one piece?? Is there anything to watch for? Does the cap screw have to come off to take out the whole piece?
It would seem its just the two screws that hold the entire body on?
Am I right on this??
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 12 (permalink) Old 05-12-2012, 03:17 PM
research the "Grambo Trick" every thing you need to know about the ACCT can be found there
post #3 of 12 (permalink) Old 05-12-2012, 03:21 PM
Member? ... check.
ZCraggRatt's Avatar
The short answer is yes, the ACCT comes out in one piece after you remove the cap screw nuts.
~~C8>
ZCraggRatt is offline
post #4 of 12 (permalink) Old 05-12-2012, 03:35 PM Thread Starter
pittdave's Avatar
thank you.. thats what i needed to know
Pittsburgh Dave
pittdave is offline
post #5 of 12 (permalink) Old 05-12-2012, 08:39 PM
Concert connoisseur
wib714's Avatar
I would take off the capscrew then insert a tiny flathead screwdriver and tur it clockwise to relieve tension on the acct, then remove the two nuts holding the body on and remove it all!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 12 (permalink) Old 05-12-2012, 08:42 PM
If you are removing it, it is not needed to take the tension out. If you are going on with it you had better remove the tension as described above.
post #7 of 12 (permalink) Old 05-12-2012, 11:35 PM Thread Starter
pittdave's Avatar
OK.. i'm confused.. I am changing to the TOC MCCTs..so the stock ACCTs are coming off, Do i need to relieve the tension on the spring to remove those or not
Pittsburgh Dave
pittdave is offline
post #8 of 12 (permalink) Old 05-12-2012, 11:54 PM
It comes out as 1 piece. You have to bend a clip for the external fuel line on the left side ACCT, but it's easy. Just be gentle.
post #9 of 12 (permalink) Old 05-13-2012, 01:11 AM
Patriot Guard Rider
The DEUCE's Avatar
NO! It is as simple as you know it is. Undo the two screws on each ACCT and remove. Follow the directions on the MCCT's and you will be done in 15 minutes.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #10 of 12 (permalink) Old 05-13-2012, 11:53 AM
Concert connoisseur
wib714's Avatar
you dont have to but it will take you literally 10 seconds to releive the tension, and that will make the mounting nuts spin right off once loosened and not put any stress on the threads. it will take you a whole 2 minutes to remove them.
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
