Odd noise in first gear - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-06-2012, 08:48 AM Thread Starter
Skankin' Vulcan
combatchuck's Avatar
So I bought my VN750 a week ago and it's been running fine. However, I noticed that when I shift down into first when I'm coming to a stop I hear a not-quite-squealing noise. It's hard to describe and I wanted to take a video but it only happens when the bike is moving and usually only when I have the clutch pulled in and I didn't want to try to operate a camera with all that. I'm almost positive it's not the wheels, the sound fits with the rpms.
Anyone have ideas on what it could be?
Thanks
Combatchuck
Looking for:
Swingarm caps
Highway pegs or engine guard
PM if you got these for sale
1986 Vulcan 750
NGK Plug Wires and Iridium Plugs
AGM Battery
Shinko 230 Tour Masters @24,400 miles
Right side rebuilt after PO laydown
combatchuck is offline
post #2 of 12 (permalink) Old 05-06-2012, 11:40 AM
Is there any way you could attach the camera to the seat or some other part of the bike to record the sound, even if the camera is not focused on it?
It seems odd to hear the noise with the clutch lever pulled in, rather than with the clutch engaged.
Does the noise come from the right side by the clutch plates?
post #3 of 12 (permalink) Old 05-07-2012, 01:16 AM Thread Starter
Skankin' Vulcan
Here's the link to the video: http://youtu.be/tTpxzJAG8AA
Sorry about the quality, and I must have hit the mute button partway through, but you can definitely hear the sound pretty good around 10-14 seconds. It does it in all gears now and only stops occasionally or if I'm stopped and idling.
Any ideas?
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
post #4 of 12 (permalink) Old 05-07-2012, 01:19 AM Thread Starter
Skankin' Vulcan
Apparently I hit the mute button abour 20 seconds in, but you can hear the noise really well around 10-14 seconds. It does it all the time now unless I'm stopped. Sometimes it will quit for a few seconds when I'm moving but then it comes back.
I have absolutely no idea and I can't investigate much because it only happens while I'm riding.
Thanks,
combatchuck
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
post #5 of 12 (permalink) Old 05-07-2012, 11:40 AM Thread Starter
Skankin' Vulcan
Third time's a charm. For some reason my posts aren't showing up. Here's the link to the video: http://www.youtube.com/watch?v=tTpxzJAG8AA
Sorry about the second half, I must have hit the mute button. You can hear the noise pretty well around 10-14 seconds. It's the high pitched one you can hear past the engine. It does it pretty much anytime I'm moving now, so I'm pretty sure it's got something to do with the front wheel rather than the engine, but I can't seem to find anything noticeably wrong with it.
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
post #6 of 12 (permalink) Old 05-07-2012, 11:46 AM Thread Starter
Skankin' Vulcan
Fourth time I'm trying to post this. Apparently I can't post video links yet because I'm new. It says it has to be approved by a moderator but from what I've read on here no one will ever approve it. I put the video on youtube so if you go there and search "Weird Noise on VN750 it should pop up right at the top. My username is similar (combatchuck1234). You can hear the high pitched sound fairly well around 10-14 secs. After that I think I hit the mute button.
I'm pretty sure it's a wheel thing at this point because it's doing it almost constantly when I'm moving. However, because I can't get it to do it when it's not moving, I have no way of checking to see what's wrong. Nothing is visible on the front tire so I'm not sure what to do.
Thoughts?
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
post #7 of 12 (permalink) Old 05-07-2012, 01:16 PM
That sounds normal to me. Shaft-driven bikes will make more whirly noises than other types. Try to isolate the sound. Does it sound like it comes from up front or towards the rear? Rear might indicate something with the final drive system. Uncertain about up front.
I am certain someone will chime in.
Oh, btw, LINKY -> http://www.youtube.com/watch?v=tTpxzJAG8AA
Peace
post #8 of 12 (permalink) Old 05-07-2012, 01:56 PM
That is exactly what my 90 sounds like with stock exhaust.
post #9 of 12 (permalink) Old 05-07-2012, 07:17 PM
Crap, I WAS in 5th gear.
Thoughts?
Sounds normal.
Kelly2001 is offline
post #10 of 12 (permalink) Old 05-07-2012, 09:03 PM Thread Starter
Skankin' Vulcan
It sounds like its coming from up front. And I don't think it's normal because it cuts in and out and wasn't doing it earlier in the week. I'll see if I can get a better video of it tonight.
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
