ACCT/MCCT Questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-05-2012, 09:49 AM Thread Starter
dirtdemon718's Avatar
ACCT/MCCT Questions
1. How can I tell if I have an ACCT or MCCT, 2. How hard is it to replace, do I have to remove motor from bike to do,etc.? Not sure what the people who've owned bike before me have done to it but want to be sure that I don't find myself stranded cause of an oversight on my part
dirtdemon718 is offline
post #2 of 5 (permalink) Old 05-05-2012, 10:21 AM
Concert connoisseur
wib714's Avatar
acct will have a small cap screw on top of it, if it is an mcct it will have a bolt or hex head bolt coming from the top of it with possibly a nut to secure it. write up on switching it in my sig line with hopefully pics of both but not sure.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 5 (permalink) Old 05-05-2012, 10:23 AM
Concert connoisseur
wib714's Avatar
that just has pics of mcct. an acct will just have a cap screw flush with the housing!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 5 (permalink) Old 05-05-2012, 01:14 PM
If only it had 6th gear..
DavesVulster's Avatar
Working on them is really pretty easy and does not require pulling the engine. The one on the front cylinder is about half way up and sticking out of the side of the cyl. pointing to the bike's rear. The rear cylinder is a lil harder to get to because it's behind the coolant bottle. Two bolts secure it to the cylinder and as wib said, there's one cap screw on the end of it (if it's the stock acct).
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #5 of 5 (permalink) Old 05-10-2012, 02:45 PM
benallfree's Avatar
I consider myself a beginner mechanic and I did this job with no trouble.
Howto: ACCT to MCCT using Set Screw
https://www.vn750.com/forum/showthread.php?t=21561
2006 VN750
benallfree is offline
