My first oil change..... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-30-2012, 06:58 AM Thread Starter
Viking
Completed my first oilchange ever on a bike - really satisfyiung to be able to do something by myself. Found a very usefull description here on the site.
I removed the oilscreen, and didn't take notice of the black gum like stuff on it, and what looked like a few aluminium particles. It didn't seem like much - and I cleaned it off - and the bike runs smooth. However after read recent posts I'm concerned about if that was parts of my dampers? Is it normal with some gum like stuff on the oil screen - it wasn't much ?
Best regards from Denmark
Torben Wallner
87 vn750
Black colored (black bikes are the fastest ones)
BOS exhaust
TOC's
Sissybar removed
Splines lubed
facebook: www.facebook.com/TorbenWallner
towa is offline
post #2 of 11 (permalink) Old 04-30-2012, 12:36 PM
Where they little black chunks or black shavings? Black shavings are usually clutch plate wear, I believe.
Black chunks definitely point to dampers. I am in the process of doing this now, the engine is out and sitting on my garage floor.
When I first got the bike, the concept of an engine pull would scare me. Now I am just excited to get her going again. The internal engine work required is very easy, and is actually the quickest part of the job. I'd say I had the internal work done in under 30 minutes (strap-wrenches are awesome). The tight spaces during dis-assembly and re-assembly are what get to you.
post #3 of 11 (permalink) Old 04-30-2012, 01:29 PM
Congrats. Now you're ready to tackle that spline lube....
post #4 of 11 (permalink) Old 04-30-2012, 02:28 PM Thread Starter
Viking
Pheeew... It sounds very well as clutch wear.... Yes, next project is the spline lube thing... But hey, when I have it off I'll might as well put on a new tire, and some new brakes.....
Will I finally end riding it....
Thanks for the input
Torben Wallner
87 vn750
BOS exhaust
TOC's
Sissybar removed
Splines lubed
towa is offline
post #5 of 11 (permalink) Old 04-30-2012, 08:38 PM
If only it had 6th gear..
DavesVulster's Avatar
If the oil hadn't been changed for a while there could have been some sludge built up and that could be sort of gummy. If the dampers were coming apart I would think the chunks would not feel gummy, although I've never seen them in mine. Clutch shavings shouldn't feel gummy either imo.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #6 of 11 (permalink) Old 05-01-2012, 04:52 AM Thread Starter
Viking
even if i tightend the oil filter as a fast as possible by hand, a few drops of oil on the ground when she gets hot. I cleaned the oil gasket area before putting on the new oil filter - added oil etc. etc.
Seems that oil drips from the oilfilter down on the starter motor....
Anyone experienced this before?
Torben Wallner
87 vn750
BOS exhaust
TOC's
Sissybar removed
Splines lubed
towa is offline
post #7 of 11 (permalink) Old 05-01-2012, 10:03 AM
Did you put oil on the ring before installing? That helps it seal up.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #8 of 11 (permalink) Old 05-01-2012, 10:23 AM Thread Starter
Viking
Yep, All done by the book :-(
Torben Wallner
87 vn750
BOS exhaust
TOC's
Sissybar removed
Splines lubed
towa is offline
post #9 of 11 (permalink) Old 05-01-2012, 11:49 AM
you didn't say what filter you are using, but make sure it is the correct size diameter to make a good seal (2.3" O.D. gasket ).
hand tight is all you really need....if you used a wrench then it is possible you over tightened the filter.
check this thread for filters that work on the VN750:
https://www.vn750.com/forum/showthread.php?t=1142
post #10 of 11 (permalink) Old 05-01-2012, 11:59 AM Thread Starter
Viking
Hand tightend with both hands, as tight as I could. So maybe I "over tightend it"?
It is a Champion f302 - should fit the bike.
Torben Wallner
87 vn750
BOS exhaust
TOC's
Sissybar removed
Splines lubed
towa is offline
