Oil Filter Size?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-28-2012, 07:48 PM Thread Starter
Oil Filter Size??
Hi All -
I'm bringing an '86 VN750 with only 3,356 miles on the clock out of it's sleep and today when I changed the oil, I noticed the (original?) filter is bigger than the recommended Wal Mart filter (ST7317) that I learned about from lurking on here...
The filter O-rings seem to line up in the right place, but with the new, smaller filter, the edge of the filter mount-plate is visible, whereas with the original filter it isn't...does this make much of a difference? I wouldn't think so, but I wanted to check..
John
Dr. Frankenstein is offline
post #2 of 8 (permalink) Old 04-28-2012, 07:57 PM
JM2001's Avatar
Originally Posted by Dr. Frankenstein View Post
Hi All -
John
There are two Walmart Filters recommended. ST 7317 and ST 6607. Same size but one is longer,both work. These are no longer available. Check my old thread
https://www.vn750.com/forum/showthrea...st+6607+filter
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 8 (permalink) Old 04-28-2012, 08:37 PM Thread Starter
Yeah, I lucked out and found one (two, actually) of the ST7317's on the shelf, so that's what I bought...it just leaves a bit of space on the plate when it's mounted, maybe a quarter inch...
Is the 6607 bigger?
post #4 of 8 (permalink) Old 04-29-2012, 10:33 PM
MANIC MECHANIC
vulcanjoe's Avatar
I use Valvoline VO-50 on mine
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #5 of 8 (permalink) Old 04-29-2012, 11:54 PM
Hi All -
John
History of changes to the vn750 over the years:
https://www.vn750.com/forum/showthrea...ght=color+year
Quote from above link:
Oil filter
- '85-'94 = larger size 2.95" diameter
- '95 up = smaller size 2.76" diameter
Oil filter (mating) plate
- '85-'93 = 13169-1921 = 2.95" (75mm)
- '94 = 13169-1921 = 2.95" (75mm)
- '94 = 13270-1170 = 2.76" (70mm)
- '95 up = 13270-1170 = 2.76" (70mm)
As long as the filter seals against the mounting plate everything is good. IMO
Vulcan Verses on oil filters:
https://www.vn750.com/forum/showthread.php?t=1142
DO I HAVE OTHER OIL FILTER OPTIONS ?
Yes. It's Sunday and you forgot to get a Kawasaki filter, or just not willing to dish out the extra cash. Here are some options that fit our bike (all years). All have superior filtering. Get the longer ones if possible. It only makes sense they usually have more surface are on the internal pleats to catch more dirt particles. Remember, these come is all sorts of colors. I do not want an orange or white filter on the front of my bike. Just use black spray paint before mounting.
First Choice: Filters about 3.25 inches long: -
Purolator Pure One PL14610, about $6. -
Mobil 1 M1-110, about $10. Made by Champion. -
Bosch 3323, about $6.Made By Champion. -
WalMart SuperTech ST7317, about $2. Made by Champion
Second Choice: Filters about 2.5 inches long: -
Purolator Pure One PL14612, about $6. -
Mobil M1-108, about $12. Made by Champion. -
Bosch 3300, about $6. Made by Champion. -
WalMart SuperTech ST6607, about $2. Made by Champion.
Re: Wal-Mart Oil Filters The ST 2808 has been replaced by the ST 3593A.
NAPA Gold has a high quality filter made by WIX that fits too. Sorry but I don`t have the part number.
post #6 of 8 (permalink) Old 04-30-2012, 07:11 AM
n2omike's Avatar
If you can't remember the above part numbers, just ask for an oil filter for a V6 1998 Nissan Maxima or a 4cyl 2005 Honda Accord. I've had both of those cars, and they used the same oil filter. It just happens to be the same filter for a Vulcan 750. (These are two of the cars the filters in the above post fit.)
05 VN750
Iridium Plugs
Spline Lubed front/rear
ignition pickups gapped
AGM Battery
Relocated MOSFET R/R
Coaster Mod
Pilot Screws at 2-1/4 turns
Slipstreamer S-08 Windshield
F&S Saddlebags/Mounts
Luggage Rack
12V Outlet
Mustang Seat
sissy bar
Oversized Pirelli Front/Rear Tire
7k miles
XR100, TTR110, DT175, CRF230F, XR250R (dual sported), XR400R
1966 mustang street/strip
4-speed, nitrous
[email protected] 135.6
n2omike is offline
post #7 of 8 (permalink) Old 04-30-2012, 04:18 PM
ifixf18s's Avatar
From Advance Auto Parts, Fram PH6017A. Less then $7. Thats the one I use.
ifixf18s is offline
post #8 of 8 (permalink) Old 05-01-2012, 11:54 AM
I just found a lot of 33 oil filters (PN#16097-1054 - for the older VN750s) for less than $2 per filter. I guess I am stocked up for a while.
