It needs to be louder! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 04-28-2012, 12:32 AM Thread Starter
Ok whats the cheapest and easiest way to make my stock pipes louder?
LeonelRenteria is offline
post #2 of 21 (permalink) Old 04-28-2012, 12:39 AM
Patriot Guard Rider
The DEUCE's Avatar
Pull the mufflers and goat (power chamber) off.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 21 (permalink) Old 04-28-2012, 12:51 AM
What's your current exhaust set up and how loud do you want to go?
Rebel13 is offline
post #4 of 21 (permalink) Old 04-28-2012, 12:52 AM
HAWK
Ccspinner's Avatar
Once you remove the stock muflers from the pipes look into the end that goes twards the motor. You will see a screen, drill that out and you will see almost streight pipe with the goatbelly removed.
Sounds great, this is what it will look like when done.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 21 (permalink) Old 04-28-2012, 01:04 AM Thread Starter
I currently have stock pipes. can u guys give me a step by step process as to "DeGoating" please i am new to this bike. and forum.
post #6 of 21 (permalink) Old 04-28-2012, 01:09 AM
Want a quick way, simply remove the mufflers! Then put turn downs in place or leave alone... That is one step up in volume. I bought the bike with that set up, but never heard it as it didn't run then. I'm almost finished making my own exhaust on her now. Still she isn't running, but will be soon.
Rebel13 is offline
post #7 of 21 (permalink) Old 04-28-2012, 01:49 AM
The cheapest was is to take off the mufflers & remove the "goats belly" and replace the short piece that the goats belly took up on either side with a piece of exhaust pipe and put it back together. Make sure the exhaust is sealed up with no leaks. You could always remove the screen later after you try that 1st because once you start cutting things you can't put them back the way they were.
post #8 of 21 (permalink) Old 04-28-2012, 01:04 PM
Leave the goats belly there, just remove the mufflers. As mentioned you can spend a few bucks and put on some angled tips. (will keep your tire from catching fire.)
Option two...leave the mufflers there and remove the goats belly. You'll have to find the right sized pipe to replace it on each side.
Option three, my favorite, is to leave the exhaust alone. All your neighbors will like you, you will be able to hear your granddaughter talk when your old, and you'll keep the public at large from hating bikers even more.
All the changes mentioned, other than the last one, do not make your bike faster, or perform better. Quite the opposite really.
My last and best compromise here is for you to buy some strong in the ear hearing aids....This way the bike will sound louder to YOU, but won't to all the rest of us that will end up hearing it.
post #9 of 21 (permalink) Old 04-28-2012, 06:20 PM
Hahaha.......
dariv is offline
post #10 of 21 (permalink) Old 04-28-2012, 09:38 PM
2000 VN 750 Senior Member
Sounds comical but there is a lot of truth to KM's comments. (Did I really just write that about KM? lol) If you really want to remove the stock exhaust with the Goat's Belly be sure you understand all that is involved and the possibility that your power will drop as will your mpg. Decide on your specific reasoning behind having louder piper and compare that to the possible end results before you do any cutting or drilling. In the end, be sure it is what you really want.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
