Help. Upper front cam chain jumped. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 04-05-2012, 04:06 PM Thread Starter
My upper front cam chain jumped one tooth (was just idling/warming with MCCT lock nut loose so I could adjust). began to chatter a bit, and i noticed the MCCT bolt backing out some. Shut her down immediately.
When both upper cam sprockets are set to where they need to be, the timing line lines up with the "T" in the FT stamp (clockwise of TDC). Guessing retarded then ? Bike runs, no nasty noises, but an occasional backfire into the intake.
Question is : Can I shift the cams/chain over one tooth without removing the head ? The chain loosens some when I back out the MCCT. Is there an easier way to get the chain more loose, w/o pulling the engine and head ?
Thanks in advance.
post #2 of 17 (permalink) Old 04-05-2012, 05:09 PM
JM2001's Avatar
I'd like to help but I don't know the answer. Hopefully you'll get an answer soon. Good luck
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 17 (permalink) Old 04-05-2012, 05:55 PM
Have you got the service manual?If not look up kanuck 69 and down load the online one on here.I would suspect that if it jumped more than one tooth you may have bent a valve.Doesn't sound like it though.
If you down load the manual you will be able to see where the marks should by with each piston where it is supposed to be.
Did the mcct's loosen up enough to allow it to jump or are your cam chains excessively worn,The DOHC Kaws are kinda hard to time with out being able to see everything at once,I hope you can figure out which cam or if both cams moved on ya,or do you think it jumped one tooth on the sprocket driving them.
I hate to hear this happened to ya,but it can be overcame ,although you may have to dig deeper than you want to make sure it's all in time.which I would recommend just to be sure Ihad it right,but you're gonna have to make that call.
post #4 of 17 (permalink) Old 04-05-2012, 06:37 PM Thread Starter
I have both the Clymers actual book, and the PDF manual. Still doesnt really tell ya how to set the cams in relation to chain.
Im almost sure I jumped just one tooth on the single intermediate sprocket, as both cam sprockets are "right" in relation to each other.
Condition of sprockets and chain was actually really good considering its an'85 with only 20k on it. Normal wear, but nothing blatantly bad.
Now, I noticed a large bolt head on the head facing the carb where there's supposed to be a spring that pushes on the upper tensioner. Wonder if I removed that, if Id have enough slack in the chain. May as well try, got nothing to lose by doing it.
What I though about doing (since lower chain and intermediate cog is where they should be at TDC) is to set the lower to TDC, then slip the chain away from the cam cogs individually and rotate them to where they should be.
If I gotta pull the motor, I may as well sell it. I cant do it by myself due to physical disabilities.
Gimme back my oil leaking pushrods and rockers !...lol....
Thanks....
post #5 of 17 (permalink) Old 04-07-2012, 04:33 PM Thread Starter
Well, I found that the main tension spring(found behind the large bolt in line with carb intake) loosened up my chain significantly. Still kinda tight though. I think mebbe if I remove the front upper chainguide, I can do it....its either that, or remove the cam covers, OR yank the motor, which I cant do.
post #6 of 17 (permalink) Old 04-07-2012, 06:15 PM
The Vulcan 750 motor can be a real PITA to work on, which is why I often complain about it's complexity. I see no reason why it needs 4 cam chains instead of 2, like all other Japanese v-twins (with the single exception of the Suzuki TL1000) The Vulcan 800 only has 2 cam chains, and so does the Suzuki Intruder, which is just a hair faster than the Vulcan, so it was not for performance. Watch Roaches videos. I believe that to get it timed right, you have to pull the heads and count links.
The motor is not all that hard to get out, you don't have to lift anything. Just put a transmission jack or something similar under it, remove the right frame section, remove the engine mount bolts, and wiggle it out of the frame. The hard part, or at least the most time consuming, is disconnecting and removing all the stuff that attaches to the engine.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #7 of 17 (permalink) Old 04-11-2012, 04:58 PM Thread Starter
Gonna try to pull the cam cover off first, and see if I can slip the chain one tooth then. If that dont work, gonna need to yank the engine, and gonna need to wait for summer for that (too cold in the garage). Sucks too, because supposed to be almost 80 on Monday.
May as well do the clutch at same time then too. Stator and R/R has been done.
post #8 of 17 (permalink) Old 04-13-2012, 07:46 PM Thread Starter
Fixed the sucker !...loosened up/removed the 2 upper tensioners (MCCT and main), set the cam cogs at TDC, stuck punches in the holes to lock em in, then jiggled the rotor back and forth until it jumped the intermediate gear back to where it was. Took a 20 mi ride, and all was cool. Whew ! Not dead in the water after all !
post #9 of 17 (permalink) Old 04-14-2012, 02:20 AM
Awesome to hear! Helpful information as well..
post #10 of 17 (permalink) Old 04-14-2012, 11:02 AM
good to hear,man
