Cooling fan blade assembly detached from motor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-04-2012, 02:29 AM Thread Starter
Got home today. Shut off bike. Instead of hearing the nice 15 second whoosh of air circulating from the cooling fan, I hear a buzzing sound that wouldn't stop. Detached neg batt cable; buzzing stopped. Checked the cooling fan and realized the white fan blade assembly not spinning when I reconnected neg batt cable. Motor working fine; blade not rotating, just loose and lots of free play. What I need to know is: 1) Is there a way to reattach it (some box fans have a blade assembly with a set screw holding it to the motor shaft. 2) If not, does anyone have one they can sell me. 3) If not, where's the best place (by that I mean CHEAPEST place) to obtain one.
Any help is surely appreciated.
Thanks
-jim
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
Did I miss anything?
Kayakrazy is offline
post #2 of 12 (permalink) Old 04-04-2012, 02:34 AM
There are replacementaluminum fans. I am considering a pair of them.
post #3 of 12 (permalink) Old 04-04-2012, 02:36 AM
Why a pair? our bikes only need one fan... and one fan will outlast the motor.
post #4 of 12 (permalink) Old 04-04-2012, 02:47 AM Thread Starter
WOW! quick response
thtanner - That looks like just a fan blade, I am correct? Will that attach to the motor (or does a motor come with it?)
Thanks brother!
-jim
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
post #5 of 12 (permalink) Old 04-04-2012, 02:51 AM
its just the blades... and yes it attaches directly to the motor... there is an alen head set screw to keep it on the motor.
post #6 of 12 (permalink) Old 04-04-2012, 03:15 AM
A pair of fans for a pair of bikes, of course!
post #7 of 12 (permalink) Old 04-04-2012, 10:53 AM
romeobravo172
romeobravo172's Avatar
PM sent
romeobravo172 is offline
post #8 of 12 (permalink) Old 04-04-2012, 11:03 AM
ahh ok.. you had me confused for a minute Tanner
post #9 of 12 (permalink) Old 04-04-2012, 01:11 PM Thread Starter
Bought metal fan blade assy on ebay. Does the plastic blade assy attach to the fan motor with a set screw as well? It may have just come loose. Contemplating a temporary fix until my order arrives, but hate to dissemble bike just to find that it doesn't attach in a similar fashion. Still able to use bike in a.m. on short trips.
Thanks again
-jim
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
post #10 of 12 (permalink) Old 04-04-2012, 01:31 PM
romeobravo172
The fan attaches with 3 philip screws, the actual part that turns is totally flat held on by a spring clip with 3 washers under it. The elect motor is fairly sizeable.
