Drilled out my baffles - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-02-2012, 11:02 PM Thread Starter
PaleRider's Avatar
Thumbs up Drilled out my baffles
Very happy with the result. I drilled 8 3/8" holes in each side. I've also painted my headlight ring flat black. Enjoy.
2004 VN750: Custom Seat, NGK Plugs/Wires, Drilled Baffles, 12 inch apes
2006 VW GTI 6MT: 3" TBE, CAI
2006 Malibu Maxx SS (Wifes ride): Straight Pipes
PaleRider is offline
post #2 of 8 (permalink) Old 04-02-2012, 11:23 PM
Definitely gives the stock exhaust some much-needed oomph.
My 86 currently has the stock exhaust with goat's belly removed. It's OK, sounds fairly sporty, but I really can't wait for a deeper rumble.
post #3 of 8 (permalink) Old 04-04-2012, 10:49 PM
Exact things I did to mine, except that I have stock Sportster muffs. Did you prep the chrome ring at all before painting ? While installing my windshield some of my paint got scratched off. Epoxy paint, or did you rough up the chrome ?
I did the 3/8 hole in baffle because I can still fill it with a 3/8 self tapping if needed (restore to stock if I move to a state with nasty regs). I didnt drill 8 though.
post #4 of 8 (permalink) Old 04-07-2012, 06:33 PM
By doing that you changed the exhaust backpressure. Hope it works for you. You might want to check the plugs to see if it is running too lean.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 8 (permalink) Old 04-08-2012, 09:01 AM
knees in the breeze!!!
Tofer76's Avatar
where did you drill them ? in the ring in the tail end or in the from the engine side under the heat sheilds
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #6 of 8 (permalink) Old 04-11-2012, 04:45 PM
I did mine from the rear (Sportster baffles have a solid plate), because I didnt need to remove the muff.....again. And if you do em one at a time, you can gauge bu sound/performance how you did. if'n ya need more, drill more.
post #7 of 8 (permalink) Old 05-04-2014, 12:19 PM
Proud Owner of '99 VN 750
furikazashi's Avatar
Did you only do this to the first plate or the plate behind it also, I drilled 4 holes in each of the first plates, and its sounds alright with a little more throat but I want a little more umph
furikazashi is offline
post #8 of 8 (permalink) Old 05-04-2014, 05:55 PM
You posted on a very old 2012 Thread....probly will not get a response from PaleRider
Maybe others experienced riders can assist, I have not performed this mod as of yet.
