Stator cover removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 03-30-2012, 03:40 PM Thread Starter
I took the stator cover off being careful I noticed a flat shim washer on the ground. Even though I was careful did no see where it came from but I do assume it came off the shift shaft but not certain any help would be appreciated
2001v750 is offline
post #2 of 2 (permalink) Old 03-30-2012, 03:43 PM
Captive New Yorker....
peterherrm's Avatar
Yes, it came off the shaft......... Might want to make sure both clips are on the shift shaft inside there while you're there...
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
