Radiator fan loose from shaft - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-23-2012, 12:54 AM Thread Starter
I noticed my fan came on but was not cooling the bike. So after the bike cooled down i checked out the fan and it would freely move around in the fan shroud and felt as if it was off the shaft. i hear the fan motor run but the fan doesnt go with it. I read a post saying that he was planning to use high strength epoxy to hold it back on the shaft. will that work or is there another known fix without having to replace the whole fan assembly. Thanks Mick
Mick51 is offline
post #2 of 7 (permalink) Old 03-24-2012, 06:01 PM
Chucklehead
dragon159's Avatar
Same thing happened to mine .... was going to look into a replacement I heard about a few years back. I think it was Muzzy's that had an aluminum fan madefor the Ninjas but fits ours. Will post when I find out particulars.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #3 of 7 (permalink) Old 03-24-2012, 07:53 PM
Chucklehead
dragon159's Avatar
Found it ....
http://www.muzzys.com/fans.html
2 into 1 exhaust
Spitfire windscreen
Plutonium plugs
More to come
post #4 of 7 (permalink) Old 03-24-2012, 11:05 PM
It's a good thing the motor is ok, a new one is $450.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 7 (permalink) Old 03-27-2012, 12:04 AM Thread Starter
got everything broken down, epoxied up, and put back together. All in all a pretty simple fix. after letting her idle till she heated up, the fan kicked on and spun. ill let you guys know how well this holds up.
Mick51 is offline
post #6 of 7 (permalink) Old 03-27-2012, 12:07 AM
Striker1's Avatar
A new motor is $450.00
1986 Vulcan 750
30,000 miles and counting
Castrol GTX 10w-40
WIX- Gold oil filter Pt.#1356 @ Napa Auto supply $8.00
Seafoam-2 oz. to every other tank of gas @ Napa-$10
Yuasa M/F battery- YTX14AHL-BS
Lubed Splines- Moly EP Grease, 1lb. tub $3.49-Autozone Pt.#561753
Sprayed U-joint with Liquid Wrench White Lithium Grease- $3.99 Autozone Pt.# 828796
Castrol Hypoy C 80w90 Gear Oil $5.99- Autozone Pt.#991558
NGK Iridium IX Spark Plugs, $8.99(x4)=$35.96 Autozone Pt.#088394.
Degoated
Striker1 is offline
post #7 of 7 (permalink) Old 03-27-2012, 01:05 PM
romeobravo172
romeobravo172's Avatar
If it dosn't let me know I have a complete unit---
romeobravo172 is offline
