engine miss? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 02-08-2012, 08:12 PM Thread Starter
1986vn750's Avatar
engine miss?
I noticed something really weird the other day. When riding my Vulcan, it runs perfectly, no missing or loss of power. However, If i rev to about 4,000 in neutral and hold it, it starts to miss and wander up and down in rpms, but it NEVER misses when riding, or under load. anything i can do? or just not worry about it. It also idles at 1,100 so smoothly. I ran some Lucas gas treatment through my system, only ridden about 50 miles on that tank so maybe that will fix it.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #2 of 11 (permalink) Old 02-09-2012, 12:09 AM
Did you check if your battery terminals are tight? The jumping tach is a good sign of a loose ground and that's about the easiest place to start looking.
post #3 of 11 (permalink) Old 02-09-2012, 01:36 PM Thread Starter
1986vn750's Avatar
Battery cables are tight. When im riding that tach is super smooth and steady.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #4 of 11 (permalink) Old 02-09-2012, 11:05 PM
cylinder kicking out
I had a similar problem.... but more evident at idle. I pulled spark plug wires to determine rear cylinder intermittent spark. Cleaned all electrical connections, new spark plug wires...no help. Replaced CDI ignitor box.. Problems gone.
Good Luck
WilliamTech
post #5 of 11 (permalink) Old 02-09-2012, 11:10 PM Thread Starter
1986vn750's Avatar
I do want to put 4 new plugs in this spring. It has Denso's in their now. I think i want NGK Iridiums.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #6 of 11 (permalink) Old 02-10-2012, 08:30 AM
trekbiker's Avatar
i put iridium's in mine and it starts and runs a whole lot better - but when i first crank mine - before it is fully warmed up - it will miss a bit until i have ridden a few miles then all is good. (the iridiums fixed everything but that) I haven't figured mine out yet - are you trying it when it's cold?
That can't be my bike - it aint movin'
trekbiker is offline
post #7 of 11 (permalink) Old 02-10-2012, 08:44 AM
JM2001's Avatar
That's typical of any engine with carbs and a choke ( a gas enricher on our bikes). The only way to eliminate the condition would be to install fuel injection. The engine should smooth out in a couple of minutes of idling at 1/2 choke.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #8 of 11 (permalink) Old 02-11-2012, 12:08 AM Thread Starter
1986vn750's Avatar
It did it when it was hot, riden after about 20 miles. But I guess it really doesnt bother me because It runs strong and smooth under power.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #9 of 11 (permalink) Old 02-11-2012, 07:53 AM
JM2001's Avatar
It could be that you have a dirty pilot jet. The pilots supply the fuel to the carbs up to 2500-3000 rpms ( IIRC). The engine may smooth out when the main jets kick in. I would try about 6 ounces of SeaFoam in a full tank of gas.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #10 of 11 (permalink) Old 02-11-2012, 11:12 AM Thread Starter
1986vn750's Avatar
Yeah, I was out of seafoam so I have some Lucas fuel treatment in there now, I've run about 50 miles on that tank. I will try some seafoam if this doesnt help.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
