engine idle speed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-23-2012, 12:28 AM Thread Starter
yamahondakawi1's Avatar
engine idle speed
I was wondering what the idle speed should be at because mine is below 1000rpm?
yamahondakawi1 is offline
post #2 of 7 (permalink) Old 01-23-2012, 12:33 AM
JM2001's Avatar
1100-1200 is recommended, mine idles and takes off best at 1200.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 7 (permalink) Old 01-23-2012, 12:41 AM Thread Starter
How can I change it?
post #4 of 7 (permalink) Old 01-23-2012, 12:55 AM
JM2001's Avatar
If you're sitting on the bike, on the left side by the rear cylinder is a black knurled knob. Turn clockwise to raise rpms.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #5 of 7 (permalink) Old 01-23-2012, 12:57 AM
By turning the black knob on the left side carb.... It's called the "idle adjustment knob"
Do this after the bike has warmed up and turn slowly abit at a time until you reach the desired rpm level ... (Just at or slightly above 1100 rpms)
post #6 of 7 (permalink) Old 01-23-2012, 01:25 AM Thread Starter
Will do thanks.
post #7 of 7 (permalink) Old 01-24-2012, 04:03 PM
Crap, I WAS in 5th gear.
Idle speed may float around a bit depending on air and engine temperature-- this can usually be reduced by adjusting the idle mixture screws.
Kelly2001 is offline
