help please! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-26-2011, 02:36 PM Thread Starter
Smile help please!
ticking in my front cylinder been told its the valves anyway to know for sure? its a 94 vulcan 750 been doin it forever still runs strong though
merleman420 is offline
post #2 of 12 (permalink) Old 10-26-2011, 02:46 PM
Details please,constant ticking or does it vary with engine temp?Is it a light ticking noise or is possibly timing chain slap(common problem ,easily cured) we need more info, it could be anything from a sticky lifter that is noisy to a cam chain issue.
post #3 of 12 (permalink) Old 10-26-2011, 04:24 PM
Seeing this is your first post, I'm guessing the bike is new to you? Like Denny said, we need more info to help you track down the possibilities. The ACCT (automatic cam chain tensioner) quite often is the culpret. When this starts to fail it does create a ticking sound. You can try the grambo trick. Here is a link too it. CLICK ME
This often is a cure temporarily. But at least it can help evaluate the posibillities.
post #4 of 12 (permalink) Old 10-26-2011, 07:44 PM
Like Kanuck said, the Grambo trick is usually a very short term cure.
However it is a quick and easy no cost test to determine if it is the Automatic Cam Chain Tensioner (ACCT), that is causing the noise.
If the Grambo trick quiets your ticking noise, there are several ways to fix it ranging in cost from almost nothing up to ~$100 for a set of TOC Manufacturings Manual CCTs.
Report back with results of the Grambo trick/test, and we will work from there.
post #5 of 12 (permalink) Old 10-26-2011, 08:16 PM
Concert connoisseur
wib714's Avatar
you can remove the cap screw from the acct while its running, you will see a flat slotted screwdriver hole inside there, when you hear the tick see if the slotted part is jumping around a little, if it does that is the culprit and an easy fix in several ways as mentioned. there is one on the front cylinder and one on the rear, most of us have problems with the front first, the rear seems to last a lot longer.
WHEN PUTTING THE CAPSCREW BACK ON JUST SNUG IT UP, DO NOT OVERTIGHTEN the threads are very weak in the housing!
1. a few ways to fix it, at first I disassembled the acct and put an extra turn on my spring to give more tension, worked for a while.
2.new acct springs from toc manufacturing 20 a cylinder
3.switch to mcct from toc, 50 a cylinder
4. homemade mcct from your old parts 4 dollars a cylinder
either route you take should fix it but number 1 and 2 are more temporary! 4 is the route I took and no problems since. # 3 is the preferred if money is not an issue.
oh, and by the way, welcome to the group!!!!!!!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 12 (permalink) Old 10-26-2011, 10:51 PM Thread Starter
thank you all for the help never done this before its already so helpful! well my front cylinder ticks continously only stops for maybe 3 secs at a time and only whenevers its idling.and if i put my hand on the top of the cylinder i can slightly feel the ticking in the motor.
post #7 of 12 (permalink) Old 10-27-2011, 02:52 PM Thread Starter
ok i think your right i can feel the ticking hard in the acct!
post #8 of 12 (permalink) Old 10-27-2011, 04:06 PM Thread Starter
that was it!
OK so i took the nut off the acct it was hopping all around in there i used a small Flathead and turned it clockwise it jumped back now it only ticks at a higher rev but no longer at an idle! thanks a bunch you guys are genius!
post #9 of 12 (permalink) Old 10-27-2011, 04:33 PM
here is the cheap way to make it a permanent fix
https://www.vn750.com/forum/showthread.php?t=17917
post #10 of 12 (permalink) Old 10-27-2011, 04:39 PM
