Somebody stop me! Oil in Coolant - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-24-2011, 01:25 AM Thread Starter
gaittec's Avatar
So I'm a total newby to the 750(one month, 3000 miles). When I bought my bike, I asked about checking the oil. The guy had had it one month also. He showed me the coolant reservoir and told me the window was the oil level.
You know what happened next. Two weeks (1500 miles) ago, I topped it off with 10w-40.
The good news- it only took about one or two ounces. Of course I have since looked at the manual and the oil change procedure here (thanks much).
I just went out and used a squirt-top off a squirt bottle to remove about half a cup from the reservoir. I kept the tube at the top of the liquid as I sprayed it into the bottle.
The liquid I recovered immediately showed up in two levels. The bottom level is a nice light green. The top 1/4" is murky brown. Of course , I'm going to flush it and clean it as suggested in the Archives. Hopefully, It will not cause future issues.
I'm posting this embarrassing situation because it might help another new guy.
Now, have your fun.
gaittec is offline
post #2 of 6 (permalink) Old 10-24-2011, 02:19 AM
Glad you caught that. I have been there where you are, we all start somewhere.
It's a learning experience, glad it's not at the cost of an engine.
We are all here to help you, so if you have any questions, please ask.
A dumb question is one that don't get asked.
RakerBill is offline
post #3 of 6 (permalink) Old 10-24-2011, 02:40 AM
If only it had 6th gear..
DavesVulster's Avatar
^^Amen to that^^… Ask away.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #4 of 6 (permalink) Old 10-25-2011, 12:52 AM Thread Starter
gaittec's Avatar
Thanks guys, I had an instructor who said "There are no dumb questions...but, they are the easiest ones to answer."
I have already benefited tremendously from reading the Archived advice and information on this great forum.
gaittec is offline
post #5 of 6 (permalink) Old 10-30-2011, 04:07 PM
Fortunately most of the oil stayed in the reservoir. Oil is lighter than coolant, and floats on top. But I would go ahead and drain the whole system, flush it out with distilled water, and put in new coolant anyway, not just because of that, but since you just bought the bike, you have no way of knowing what is in there. I would also do an oil and filter change, change the oil in the final drive gearcase, and the most important thing, the spline lube.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 6 (permalink) Old 10-31-2011, 01:20 AM
Concert connoisseur
wib714's Avatar
Originally Posted by vn750rider/jerry View Post
fortunately most of the oil stayed in the reservoir. Oil is lighter than coolant, and floats on top. But i would go ahead and drain the whole system, flush it out with distilled water, and put in new coolant anyway, not just because of that, but since you just bought the bike, you have no way of knowing what is in there. I would also do an oil and filter change, change the oil in the final drive gearcase, and the most important thing, the spline lube.
x2!!!!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
