Sportster pipes... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-22-2011, 11:13 PM Thread Starter
If only it had 6th gear..
DavesVulster's Avatar
Sportster pipes...
Anyone running them with the goat's belly still in tact? If so how does the sound compare to the original exhaust?
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #2 of 7 (permalink) Old 10-23-2011, 03:42 AM
Concert connoisseur
wib714's Avatar
running mine with no goat, sounds good I think, not real loud but you can hear it. I like the looks too!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 7 (permalink) Old 10-23-2011, 04:22 PM Thread Starter
Thanks man!
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #4 of 7 (permalink) Old 10-23-2011, 07:42 PM
I run them with the goats belly. I like them just fine. not loud but a more mellow tone.
post #5 of 7 (permalink) Old 10-23-2011, 09:45 PM Thread Starter
Thank you. You had dynas before didn't you? Are the sporster muffs louder than drilled stock pipes? That's what I'm running and I like that found but was hoping for a little beefier sound but not too loud as to make me wanna set my face on fire after riding highway for a while? Also are you using the stock heat shields to cover the unchromed belly? Sorry for peppering questions, just want to make an edjucated choice. Thanks again.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #6 of 7 (permalink) Old 10-25-2011, 12:31 PM
Everything is stock on the exhaust but the mufflers. You will have to make a mount to hold them in place, but that's a simple flat bar with holes. Done right, you don't even see it. As for the sound. It is quieter than stock drilled. I've heard wib714's & I think it sounds good. Same sound as mine just a bit louder. If I was to do it again I would probably eliminate the GB. Minus the GB I would say they are comprable to stock drilled. Maybe a tad quieter.
I've been with cobra slip ons, louder & canny (my opinion). Stock drilled, same sound just a bit louder & deeper as you know. Plus I love the look of the dynas/sporster muffs. I had them once before yes & went back to them.
post #7 of 7 (permalink) Old 10-25-2011, 12:35 PM Thread Starter
Great. Thanks again!
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
