$20.00 De-Goat! - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 43 (permalink) Old 11-01-2011, 04:50 AM
See, I have the v&h on mine and I don't really mind the sound at highway speeds. Yes its a little high but really its not too noticeable to me. Even the stock systems I have heard have a similar tone at higher rpms. This is really one of the most subjective topics there is IMHO.
post #12 of 43 (permalink) Old 11-01-2011, 07:58 PM
Well...
I finally got my pipe and did it, all went fairly well on the right side, but had problems with the flex sealing on the left header. So I carefully peeled off the stock lead-soaked gasket from the belly, and used that as a sealer/shim. It worked. Thing is, the prev own yanked the baffles already, and now this is WAY too loud for my liking. Gonna look into mounting a pair of stock Snortster muffs on instead. Loud was ok when I was in my 20s, 30s and 40s, but now, I just dont want it. May even have the hole in the old belly brazed and reinstall it. Was OK then....Really, running degoated and debaffled, may as well run drag pipes and make it look nicer, lol. *shrug*....
post #13 of 43 (permalink) Old 11-02-2011, 02:20 AM
If only it had 6th gear..
DavesVulster's Avatar
Absolutely right. Exhaust sound preference varies like musical taste. I bet the VH's sound sweet. I'm one of the one's that prob wouldn't like it on the highway tho. Again, if only we had 6th gear, ha ha.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #14 of 43 (permalink) Old 11-02-2011, 02:24 AM
Wolfie, The Deuce has a set on snorts that are in great shape. I was gonna snatch them for my V and then the cage busted so I gotta deal with that 1st but he was offering them for very reasonable $'s just so you know.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #15 of 43 (permalink) Old 11-02-2011, 02:47 PM
Saw that...
Saw that...thanks bro....think Im gonna hit my local custom shop first (10 miles, no shipping)...see what he has...and I just inquired about a complete sys with belly (RakerBill)...just waiting to find out location for shipping costs.
I'd almost rather borrow the cash and do that...I want QUIET !, lolol...
Tough to get stuff ya needs when ya live on $30/wk...
post #16 of 43 (permalink) Old 11-02-2011, 04:44 PM
May rethink for this year.
May rethink for this year. Got her fired up, and once I fixed the wire issue I had, the front cyl fired too. Had a leak in front even w/new crush Harley gaskets (rear sealed fine). But Harley calls for 2 different ones depending on year. Both are for the EVO engine. One is just flat both sides, the other has an added taper which goes towards the pipe. I think I need the tapered on my VN700. Mebbe a lil diff for the 750 ? Either way, ridable for this season once I fix the front leak.
One question. The acorn nuts that hold the manifold down are shot. I even ground off the tip to be able to crank down a lil more. Need new nuts (lol).
Anyone offhand know the metric size and pitch for the manifold studs ? They seem to be an M8, but an M8/100 pitch wont work. Mebbe Mom will buy me a set of nice pipes for my BDay in Jan, lol.
post #17 of 43 (permalink) Old 11-02-2011, 06:40 PM
Fyi...
...For all's info...exhaust studs are M8/1.25 pitch. My local Harley place told me that. He also has "plenty" of stock Harley mufflers used for $20 each he told me....boy oh boy...need to save up...this guy is a GEM !!!!
Unique Cycle in Hewitt, NJ...seats, pipes, fenders....you name it...most like new and were swap-outs for customs. And he's my age too ! Im LIKIN' it !
post #18 of 43 (permalink) Old 08-28-2013, 11:25 PM
fargojake's Avatar
degoat with crossover pipe
I removed the goat and got a few pipes and a flex pipe from local auto parts store. Used whole saw in a drill press and welded in flanges for flex pipe. Read it helps with the balance of the twin cylinders.
Jumpingjerry likes this.
2002 vn750 12K+
custom stainless steel toolbox cover.
removed goat and replaced with crossover pipe.
drag handlebars.
kuryakyn grips, pegs and control covers.
removed license plate light.
relocated regulator.
coil power relay.
mcct conversion on front.
installed coasters.
recovered seat.
earshaved and rejetted.
custom metallic blue paint.
added hard saddlebags with taillights.
lubed spline when changing tires
eventually add volt meter.
fargojake is offline
post #19 of 43 (permalink) Old 08-29-2013, 12:44 AM
Another several year old post brought back by a the first post of a "new" member....
You're not a robot too are you fargojake????
post #20 of 43 (permalink) Old 09-19-2013, 10:20 AM
fargojake's Avatar
don't think I'm a robot
This was first mod I did. Just didn't like the way the bike sounded, was too tame. Punched out screen in baffles but wasn't enough. Started an addiction. Now I want to coaster and do the ear shave and rejet carbs. Will be winter project when I have tank off to paint everything dark metallic blue.
2002 vn750 12K+
drag handlebars.
coil power relay.
installed coasters.
recovered seat.
