Front bevel gear case removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-09-2011, 04:27 PM Thread Starter
Heya Guys,
Pretty much got the engine out except for the front bevel gear case.
I have all the bolts loosened.
My clymers says to "Remove the front bevel gear case as described in this chapter" - However - I must be blind. Having looked through the entire chapter 4 I cannot see the heading "Front bevel gear case removal"
Clymers does not say to remove the shaft - So I have not -
Help
Please if somebody could take some pics or leave some detailed instructions on this final but crucial step in getting the engine out - I would be very thankful.
Thanks
Andrew
Andrewr is offline
post #2 of 9 (permalink) Old 10-09-2011, 04:43 PM
Look here. See if this helps.
https://www.vn750.com/forum/showthread.php?t=18289
post #3 of 9 (permalink) Old 10-09-2011, 07:21 PM
Concert connoisseur
wib714's Avatar
if your sure ALL the bolts are out just tap it easy with a mallet, should pop right off, be sure to hold on to it tightly and keep the closed or outer part down there is a gear inside that will fall out if I remember right!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 9 (permalink) Old 10-09-2011, 08:22 PM
Chucklehead
dragon159's Avatar
^x2 If I remember it's 7 bolts removed, clutch cable removed, rear exhaust removed, and pull straight towards yourself. The shaft stays in until you pull towards the front of the bike.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #5 of 9 (permalink) Old 10-10-2011, 10:07 AM
Hi Andrew,
With all the bolts out the case should wiggle foward. It should disengage from the driveshaft but, if it doesn't the drive shaft will come out aways with the case, then you can separate them. There is a spring and damper gear on the engine side of the case, they slide off easily so watch out.
Pull the driveshaft out of the swingarm tube and check the splines at the final drive end for lube or lack there of.
skrapper is offline
post #6 of 9 (permalink) Old 10-10-2011, 10:10 AM Thread Starter
Okay - Got it -
Had to take a really large socket and put on on that "Keyed" bolt in the front and rotate slightly. This gave me the torque to seperate the gasket and the bevel gear.
Broke the gasket - But I figured I would be replacing lots of gaskets anyway before all is said and done
Andrew
Andrewr is offline
post #7 of 9 (permalink) Old 10-10-2011, 11:38 AM
ifixf18s's Avatar
Something to keep in mind while you have the gear case removed. The clutch lever can spin, need to keep it from doing that. There is the pin gear that can get positioned incorrectly. It is the pin that pushes on the clutch push rod. When I had my engine removed I did not pay attention to that and the clutch lever got spun around a few times. this caused the pin to be out of place and I could not get the gear case back on the motor.
ifixf18s is offline
post #8 of 9 (permalink) Old 10-10-2011, 03:31 PM
Originally Posted by Andrewr View Post
Heya Guys,
Help
Thanks
Andrew
"Front bevel gear case removal" is in Chpt. 4 of the Clymer manual on page 199.
post #9 of 9 (permalink) Old 10-11-2011, 10:18 AM Thread Starter
Welll SHEEEEEEEEEEEEIT - I guess I need to have my eyes tested - (think that happens next month anyway -
Thanks
Andrew
Andrewr is offline
