Quick ACCT Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 10-07-2011, 12:14 AM Thread Starter
kcdude's Avatar
Question Quick ACCT Question
The outside oil pipe is blocking the front Cam Chain Tensioner. By looking at the service guide, it looks like you need to remove the engine to take off the outside oil pipe. I need to replace the chain tensioner and would rather not mess anything up, so I'm having a mechanic do it tomorrow. I've been told over the phone it will probably be an hours worth of labor. Although, I'm starting to worry they don't realize how much work might be involved. If they need to remove the engine and carbs, the job might take a lot longer. Do you think the mechanic (multi-brand motorcycle servicing/certified Kawasaki dealer) could do this job in an hour?
For those who are curious as to why I'm having this done, I tried the Grambo trick only to find out that I cannot put the cap bolt back on the tensioner since the internal threads are completely shot.
kcdude is offline
post #2 of 20 (permalink) Old 10-07-2011, 12:22 AM
If only it had 6th gear..
DavesVulster's Avatar
Nooooooo. You can just bend the tab to the side and remove the tensioner. DON'T let them charge all that labor! 15 minute job my friend. Ok say 30 min's if you've never been into it before.
Just be careful not to twist the oil line. If you do it slowly you'll be fine. I bent mine out of the way, did the work on my tensioner and bent it back no prob.
EDIT ok just re-read your post. I thought I read 'hours of labor' and noticed you said 'an hour's worth' (getting tired) so I'm not hyperventilating anymore. If you've done any work at all to your bike yourself, this is not a hard job to do. There are posts with pictures that show you step by step. Just a thought. Take care.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #3 of 20 (permalink) Old 10-07-2011, 12:27 AM Thread Starter
kcdude's Avatar
Thumbs up
It's that easy eh? I knew there had to be a better way. Thanks a lot, I'm definitely going to give it a go in the morning. I have the part, I'd rather save the money for sure!
kcdude is offline
post #4 of 20 (permalink) Old 10-07-2011, 12:51 AM
There ya go, you'll do fine. 'wib714' has a great thread with pictures on the accts. Best o luck with it.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #5 of 20 (permalink) Old 10-07-2011, 08:56 AM
JM2001's Avatar
X2 Very easy to do
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 20 (permalink) Old 10-07-2011, 09:13 AM
Concert connoisseur
wib714's Avatar
heres a thread in my link, my 14yo could do this in a half hour! dont take it to a shop for this!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #7 of 20 (permalink) Old 10-07-2011, 09:19 AM
Concert connoisseur
wib714's Avatar
and if you are just replacing springs that is just as easy. there are links to how to do it on here as well!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #8 of 20 (permalink) Old 10-07-2011, 08:42 PM
What part do you have? Ma Kaw considers the ACCT to be non repairable. The only part they sell is a whole new ACCT for ~$70 last time I heard.
TOC Manufacturing sells a heavy duty spring set for both ACCTs for ~$20, or Manual tensioners (MCCT) for ~$50 each.
LINK: http://www.tocmanufacturing.com/ACCT.htm
Regarding the mounting tab on the oil line, here is another option.
Bend the tab out straight to remove the ACCT. Dave V. mentioned that he was able to bend his back w/o breaking it, BUT if you have bend it again a time or two, the steel will eventually get brittle and break.
You don`t HAVE to bend it back to re-attach, as the oil line is plenty strong enough with out it.
If you feel better by supporting the oil line there, get a little 1", 90* bracket and attach one arm to the oil line tab, and the other where the tab was originally bolted on the ACCT. Just as strong as the original, and easier to work on later if needed.
post #9 of 20 (permalink) Old 10-07-2011, 09:12 PM
Good point OHC. Metal doesn't like to bend more than a time or two.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #10 of 20 (permalink) Old 10-07-2011, 11:46 PM
Concert connoisseur
wib714's Avatar
I'll second the oil tab support, it has plenty and mine has been bent out the way for a few years now!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
