Getting Closer - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 10-02-2011, 11:55 PM Thread Starter
Getting Closer
Well, I worked a few more hours today on getting the engine out.
Got the pipes and the radiator off. Now I gotta figure out what's next
Andrew
Andrewr is offline
post #2 of 8 (permalink) Old 10-03-2011, 11:30 PM
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
And? Your doing all of this because ??
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
post #3 of 8 (permalink) Old 10-04-2011, 12:30 AM Thread Starter
Because some C*&%^ Sucking Mot(*&#$%^#@$(&*#@$^%@#$()* decided that it would be a good idea to weld 1/4 inch onto the acct and stretch the cam chains to nearly breaking. And rather than wait for a piston to come shooting out the engine block, I figured that I would pull the engine, crack it open, and see what else the aforementioned SOB has done to the engine.
So essentially a complete engine rebuild.
Andrewr is offline
post #4 of 8 (permalink) Old 10-04-2011, 12:31 AM Thread Starter
So Question - getting the engine out the frame - any suggestions.
I have been told to loosen the bolts, and then lay the bike on it's side, and completely remove the bolts. Then pick the frame up again.
Any other suggestions?
Thanks
Andrew
Andrewr is offline
post #5 of 8 (permalink) Old 10-04-2011, 03:50 AM
Chucklehead
dragon159's Avatar
I used a floor jack under the engine with the bike on center stand. Removed the removable lower frame rail, then mounts and eased it down to the floor. Helps to have someone helping to balance everything. Don't forget to pull the bevel gear case, makes it easier than fighting the driveshaft.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #6 of 8 (permalink) Old 10-04-2011, 09:20 PM
If only it had 6th gear..
DavesVulster's Avatar
Wow man... I thought I got pissed. Ha ha, ,yeah it sure sucks when geniuses get a hold of a mig to play with. It it like the bigger hammer theory? Anyway, I haven't had the pleasure (choke) of yankin the motor on mine but it sounds like dragon's suggestion makes more sense than the other. Good luck.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #7 of 8 (permalink) Old 10-05-2011, 12:04 AM Thread Starter
hmm. I will have to look at that in the daylight and see if I understand what you mean.
Thanks
Andrewr is offline
post #8 of 8 (permalink) Old 10-05-2011, 12:27 AM
Have you got a service manual or downloaded version of the same?
Link to it in the first thread in this post:
https://www.vn750.com/forum/showthread.php?t=17667
The subframe on the right side is held on with two allen head bolts top and bottom.
The subframe has to come off to remove the engine out the right side.
(Engine has to come out right side.)
This is a picture of the subframe bracket you are looking for, only this one is on a modified subframe on the left side.
https://www.vn750.com/photopost/showp...user=1321&sl=e
jrallus (sp) has a link with an engine removal for a stator replacement.
Unfortunately I can`t find the link right now.
