straight pipe question... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 10-01-2011, 04:53 AM Thread Starter
if i run just straight pipes, is it going to wear my internals on my bike down over a short period of time?
stuicide09 is offline
post #2 of 2 (permalink) Old 10-01-2011, 05:53 AM
It shouldn't have any affect on the internals. You will need to however keep an eye on the plugs to make sure your not running too lean.
It would be a good idea to re-jet slightly richer so as not to run too lean.
If it runs too lean, you can burn a piston and or valve.
The plugs should have a slight gray/tan color if you are close.
A white/gray plug is too lean.
If you are running the stock air filters and plenum, you might get away w/o having to re-jet.
Someone with more carb experience will chime in if I'm steering you wrong.
You might expect to lose some bottom end if IIRC.
RakerBill is offline
